ok building a mild 350 motor for a daily driver for a buddy.... he has a set of 2.02 heads and a stock bottom end 350... the heads have been millied for more compresion... the motor is going in a 89 1/2 ton truck.... this is a cam i found would it be to big ...if so what would be a good pick.... he was very spacific on wanting it to sound radical... ( i tryed to explain it would suck to drive) but i will do what he wants.....
Bigger is always better.
Needs 11:1 compression.
10:1 overall drive in first gear.
2800 stall
Headers and the Loudest exhaust he can stand.
650 or 750 carb
Non-ECM controlled HEI distributor
Make sure the valve springs are the correct ones for the cam
OK well ...we are running the stock bottom end on pistons.... so I should go with a smaller can hu.... what should I look for lie lift and duration sizes for cam....
A lot of cam manufacturers offer retro "sounding" cams that work well.They are similar to the old GM 350 hp 350 cam. Use a hydraulic flat tappit cam for that lumpier idle.With stock compression a 106 degree intake centre line have a bumpier idle compared to 110 or 112. 450 lift is probably enough.really depends on how high you want to rev ,,,use headers on this application as stock manifolds seem to tame the cams sound a little.270 ish advertised duration is plenty
OK just baught a Crane energizer 100042 can....specs say its 210/210 duration.... with 266/266 duration at 50" and has 440/440 lift on 110 lsa ..... will it work good in what I am wanting ....I am worried about the idle being smooth
If the owner wants a radical sounding cam, that's far from it. It will perform great, but very smooth idle. Wont be much more than what some refer to as an "RV cam".
that Howards racing cam is a lot bigger than the original posted cam. That would have a very very lumpy idle,especially because its hydraulic.You would need vortec heads to make the best bang for the buck.
Crane makes/made an Energizer cam with 218@.050 and .450 lift ground on a 106LSA that would sound pretty snotty and also be within a good size range for that build.
With a smaller LSA you will get a narrower "peakier" power curve,though.
Yep, 78Monte is right on, the 106 lsa makes it sound nice but not too big to have drivability probs. A mild stall will still help a lot though, min 2,500.
since i'm guessing that they are stock smog style heads that have been milled down for more compression, I would say that there is no point in going over .450-.470" lift max on this motor cause the heads wont support any higher of a lift. as mentioned tighening up the LSA on the cam will give it a choppier idle, a would recomend a cam in the 220° @ .050 range with around .440-.460" and a 108LSA. matched with some headers and 2.5" exhaust and some 2 chamber mufflers, I recomend the Thrush welded mufflers (i use them on my truck, and i've had a lot of complements). a 600-650 vac secondary carb will do fine or if you can find one and know what you are doing then go for an older 750 Q-jet. He will have a lumpy idle but it wont be crazy. the problem i see here is that even though he will have a lumpy idle he still wont likely have over 250-280hp due to the heads. so my near stock GMC 2500 with the 340hp (factory) 6.0L will still hurt him.
*for a decent performing and sounding motor you will need to change the heads*
it would have a decent idle, it's kinda of on the boarder with whether it would need a higher speed stall converter or not. i think you could get away with a stock converter. but if it where my project i would put a 2500-2600 stall in it. and if you are running anyting larger than a 30-31" tall tire then i would recomend atleast 4.10 gears. epecially since the truck should have a 700r4 in it.
before you go and order that cam you will want to check and see if the stock heads w/ what ever springs, stock or aftermarket can handle .465" lift. I personally think it will need new springs and shims because i would want around .050" before i got into any kind of coil bind issues, so you would be looking at a set up that had atleast .500-.525" coil spring depression in to it before bind. not to mention you will have to look into what seat pressure ISKY recomends for this cam and match that too.
i still think that another set of heads would be a worth while (even money wise) purchase. the problem is that you have set your self up with those domed pistons so you will have to go with around a 70-72cc combustion chamber heads to get your compression levels down to a decent level.
may i ask why you went with a .015" shim gasket? I hope that it wasn't for more compression cause you could very well end up with some bent valves pretty fast if everything else doesn't check out.
Having the 106lsa and a lot of overlap can be used if everything else is setup right, especially with some stall to get it into the useable range, but for a turbo or twin turbo app. you can't use a lot of overlap due to the fact that you are pressurizing the intake charge and will push cylinder pressure out the exh. ahead of time, naturaly asperated won't as bad, so have to stick with a smoother idle, but power galore. Why such a tall rear gear ratio, man sounds like 200mph with a 2.73, the turbo's would come in a lot quicker with a better ratio like 3.42's and won't need too much stall either.
turbos come in off idle and pull all the way to my 5,500 rpm limit
and yes i plan on doing 200 mph with it down at the salt flats this year just need to get some more saftey equipment before the car is legal to go that fast on the salt.
not to mention the speedlimit on the highways here is 80mph and ill be dailing driving this car for the most part, and i make a few 120 mile round trips a week. so want to keep the low gears for milage
Man, 80mph there, nice, real nice. I bet there is a whole sh@t load of safety equip for running that fast, can see why the 2.73's then, makes sense. Have never done that, but used to go on road trips on our Northern highway's at 150mph for extended periods on 3 different street bikes I had when younger, glad to live past that, but was fun, so doing it leagally on the salt would be pretty sweet.:thumbup:
actually its not to bad, ive built the car to go 9.0's at the track and be legal, so i dont have to add to much for the salt flats to be legal, there are a few things though that i need to do like remove the steering wheel lock, and disabling the door locks
So at 9.0's you must be fully caged and what 5 point harness, how about fire system for either is it needed too, not for 9.0's but what about the Mph on salt. have you ever raced on the salt at all and if not do you start in the lowest class and work your way up to be legal each time, i imagine a lot of diff classes too. what else is done on your build, suspension too.
10pt cage,fire suit 6pt harness for the drag strip plus an nhra comp license
for the salt i have to add in a fire supression system 5lb engine, 6lb in drivers compartment, need a different drivers seat, hans device. i will run the 130mph class the first day, 150mph class the next day, then whatever liscencing passes i need to make before i run 200+. this will be my first time ever on the salt. even if its ur first time u can run the 150mph class with nothing more then a 5lb fire extinguisher and helmet with a bolt in rollbar
im keeping the front suspension stock for the salt with the exception of 1.5 inch drop springs. on the dragstrip i have some poormans 90/10 struts and drag springs.
for the salt on the rear ill have 1.5 drop springs , 3 way adjustable shocks,lcarb, adjustable lower control arms, adjustable panhard bar
the only difference is for the drag strip ill be using the stock springs instead of the drop springs
when i do the 4l80 trans swap ill be doing a short tq arm setup with the mount moved to the crossmember instead of the trans tailshaft
Ya I agree on the crossmember than stock on the trans case, they take to much abuse there, had to modify mine on my 2000Ws6 trans am I had last year, to much abuse for the trans to take, also the panhard bar stock is crap too, modified it too. The 4l80 will be a nice change, buying a modified one I imagine, what brand. That's where your stall will come in I see.
I am looking at a TCi Street fighter #371000p1 700r4 trans kit with 2,400 stall convertor for my neighbours 72 Gm 2wd truck that was a 3spd std trans and all it needs according to TCi (it is included) is lockup kit for 4th gear. Seems like a good buy for $2,400, includes fully manual trans for 400hp up,cooler/synth.oil/dip stick and only putting it behind a 400small block at approx 420hp. Know anything about these trans.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
