I had this under the "Compressor which one to buy" thread and oldred said it should have it's own thread so maybe it would help some of us in the future, I hope it does
My son and I bought a commpressor, it was a 60 gal. 6hp 220V, it was a good compressor, it would put out enough air to run my sand blaster non stop if I wanted to push it, BUT , it has a V-twin pump on it, one of the oilless type compressors, you could look up under the plastic cover on it and see the bottom of the pistons,cylinder walls and the rods, it has sealed bearings on the rods and the wrist pins,
I turned it on one day and heard a weird noise and seen a puff of dust come out of it, I didn't think much of it at the time but from that day on I noticed it was takeing longer than normal to build up air pessure and shut off and I would run out of air very quickly when doing any sand blasting,
It was out of warrenty by this time , I put a new filter in it but that didn't help a bit, I took the plastic cover off of it and looked at the bottom of the pistons and noticed a lot of scareing and scratches on the cylinder walls, so I took it apart, the pistons on this thing are only like an inch tall, they have a neopreme(sp?) ring on them instead of a steel one and the rings on both pistons were worn down the metal on the pistons
What had happened is ,I have a lot of those wasp called Mud Dobbers around here and they had built their nest up under it on the cylinder walls,it had been a while between uses giveing them the time to build their nest, their nest being made of dirt and sand ate the rings right up on it when I turned it on, this was the noise and the puff of dust I had seen earlier, I looked and parts of the nest were laying on the floor under it,
This a poor design if you asked me, I wrote to the company that made the commpressor and complained about it but I never heard a thing from them, I also asked for a parts list so I could rebuild it , they have yet to send me that either,I bought a new smaller compressor with a twin cylinder that is sealed completely up, the old fashion kind that you have to put oil in ,so if any of you have this type of compressor here is a tip for you,
You might want to take some small mesh screen and put it around the top of the compressor, like window screen, and tape it along the bottom of the tank to keep these wasp out, it is a shame that a tiny wasp can destroy a $600.00 machine but they can, I hope this helps some of you
This is a Charge Air Pro, Made by the Devilbiss Air Power Co. by the way
