We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 10-08-2005, 06:22 PM
beemdubya beemdubya is offline
Muffler fabrication questions
Im building a custom porsche 911 with a vw engine in it.. however they dont make an exhasut system fitting my needs. i plan on making a stainless steel muffler but i need to know a couple things first. i want the muffler to be a 1 in 2 out design. the muffler will be similar to the mufflers found on late 80/s early 90s firebirds and camaros. does any one have a cut away of one of these? i dont know how to get the 1 pipe to merge with the 2. one side will have an inlet and and outlet.. the other side will have an outlet in the same spot as the other side outlet. also where do i get the perforated tubing and packing to build this.. thanks
Old 10-09-2005, 07:30 PM
68 olds 68 olds is offline
why cant u use a camaro muffler
Old 10-09-2005, 09:27 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
A muffler with internal tubes and baffling like this should work well for ya.
You can make your own perforated pipe by drilling many small holes in them.
Use the course steel wool found in hardware stores.
Old 10-09-2005, 10:10 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
OneMoreTime's barnstar
Wiki editor
Wiki Edits: 3
Flowmaster
Those guys have a number of different sizes available in the 80 series which is close to what you need might be a good idea to check them out before spending a good dela of time and money roling yer own..
OMT
I would rather make it work than make it popular..And if it does not work it will not be popular..
Old 10-09-2005, 11:04 PM
I could buy a camaro muffler bu they arent stainless steal and they dont have 3.5 inch inlets.
Old 10-09-2005, 11:07 PM
Does the exhaust go through the packing? where do i put that at?
Old 10-10-2005, 04:08 AM
F-BIRD'88's Avatar
Yada Yada Yada
the packing goes in the muffler case aroundthe tubes.
Old 10-10-2005, 07:11 AM
baddbob baddbob is offline
If you pack it full of steel wool there's going to be some serious backpressure problems. You could leave it open like a turbo muffler design with no packing. Turbo mufflers are just regular mufflers with no packing. Another option would be to make a perforated sheetmetal shell that goes around the tubes then wrap that with steelwool or glass then put your outside case over that. With a 3.5"inlet it sounds like there is going to be a need for some airflow so you're going to need open areas between the internal tubes. I think you've got a cool idea---making your own muffler!
Old 10-10-2005, 07:47 AM
benwantland benwantland is offline
No offense, but I can't imagine any VW engine ever made needs a 3.5" inlet, and, for maximum performance, your exhaust system should be sized to the engine's capabilities.
Old 10-10-2005, 10:56 AM
camarochas camarochas is offline
Big Block Z28
Call Flowmaster, give them your engine specs and they'll tell you the best choice in mufflers. There's more flow technology in an exhaust system than most people realize. It's not all just "big pipes."
Old 10-10-2005, 11:05 AM
sel2real sel2real is offline
Drive it Like u Stole it!
vw motor in a porche, or porche motor in a vw? i've heard of people doing the latter, but not the first one!
Old 10-10-2005, 11:55 AM
Well im using a vw engine out of a 94 passat.. vr6.. its being built for a big turbo set up pushing around 650hp to the wheels. its liquid cooled and still in the same family.. my second choice was a subaru engine but i cant see myself putting japanese parts in this thing.
It is sized for this set up.. im not just throwing crap together. im getting my engine info from a freind that had the same set up in his 1998 vw gti he went 10.4 in the quarter.. but he didnt have a muffler on his.
Old 10-10-2005, 11:57 AM
With a turbo set up it doesnt really affect it.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Muffler fabrication questions"
muffler choice Steve B Engine 9 10-15-2007 02:17 PM
Fabrication Tool Questions sifua Body - Exterior 15 08-15-2007 11:57 PM
Building a muffler TurboS10 Hotrodders' Lounge 15 03-24-2004 04:09 PM
Suspension-Brakes-Steering Common Questions Jon Suspension - Brakes - Steering 0 10-16-2003 03:19 PM
Questions, questions, questions? slider in wa Transmission - Rearend 2 09-27-2003 02:01 PM
