Muffler formula - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2004, 12:50 PM
8843astro's Avatar
Muffler formula
Do you guys think this is a good rule of thumb when looking for a muffler?
Muffler formula
Just want to understand how to go about getting the correct muffler for a certain setup.
Old 05-17-2004, 01:02 PM
exh question
Cheak this site with some david vizard dope
http://www.geocities.com/MotorCity/T...92/vizard.html
If that dosent work just type in, David Vizard Exhaust Article
Old 05-17-2004, 11:07 PM
Dynomax & Vizard have the same rule-of-thumb: at least 2.2cfm/hp for negligible loss from back pressure.
Old 05-19-2004, 02:25 PM
8843astro's Avatar
Is this really important or just go with a 2.5in pipe and 50 series flowmaster?
Is there another rule of thumb to go by?
Thanks
Old 05-19-2004, 04:55 PM
Exh. Q
Astro
2.5 " pipe is the way to go, maybe when you step-up to 427 plus cu.in. is it time to go to 3" pipe.
You know the hot setup these days is to use a synchronizer after the headers. Dr Gas makes the kits, With this setup each of the engines cylinders exhausts through both mufflers and back pressure is of little issue.
I run this type of system behind the 383 in my Monte and i like it because coupled with the geardrive whine she sounds sweet as i tach-out on my way through the gears, the syncro setup adds a little bit of that Indy car sound.
Mufflers are FlowTech Raptors, cheap, not to quiet, not to load
and good reverse flow design.
Go with the flow bro.
