Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Muffler/pipe disassembly tool
Old 12-19-2006, 09:15 PM
russlaferrera russlaferrera is offline
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
muffler/tailpipe disassembye
Sorry I mis read your post..
Can you use 2 muffler clamps opposing each other on the tailpipe with 2 pieces of 1 1/2 angle iron with a 1/2 hole for threaded rod cut to a length to reach the muffler. Put some angle or flat stock against the muffler so the treaded rod will not damage it. Using a nut between the angle iron you should force the pipe out A little heat may help...russ
