Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Multi-section driveshaft
Old 01-12-2006, 10:47 AM
curtis73's Avatar
curtis73 curtis73 is offline
Hates: Liver. Loves: Diesel
Wiki Edits: 16
CV joints will transfer power over a larger angle than Ujoints and they'll do it without vibes. I think the complexity of the system will give you fits though.
I often gave consideration to using a solid drive shaft instead of a hollow tube. That would add a little weight, but sure would save some room. You could use a series of ujoints and carrier bearings, but the straighter the better.
