Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Multi-section driveshaft
Old 01-13-2006, 07:15 AM
woodmanscott@hotmail's Avatar
woodmanscott@hotmail woodmanscott@hotmail is offline
I did not read all the responces to your multi drive shaft deal but did you think about using ,, i think it is a didge 4x4 set up or an older chevy full size truck .. but one i have seen dumps out on th epassenger side of the vehicle which might give you more clearance.. dont know what kind of body your going to use.. also the jimmy blazer uses a small transfer case as well as the bronco two. just remember this the more complicated the plumbing the easier it is to stop up lolol
