Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Multi-section driveshaft
  #17 (permalink)
Old 01-16-2006, 01:47 PM
ckucia's Avatar
ckucia ckucia is offline
Conestogaman,
Thanks for the info on Darius (UtahTorque). I've come across a bunch of his posts on other forums. We seem to have been researching a lot of the same issues.
I knew he was on this board, but I couldn't remember his screen name.
Oddly, he's going with the same engine in his Studillac that I've been working towards with my project - a Cadillac 425. Its essentially the same block as the popular 472/500s, but was significantly lightened (by around 75lbs) making it lighter than an iron SBC. Torque is around 300ftlbs stock which should be about perfect for what I'm trying to pull off, assuming I can fit it in. Also, 300 ftlbs is a reasonable torque level for most manual transmissions to accomdate without scattering.
I'm trying to build a driver - once I get it together, I want it to stay together so I can actually drive it. I think I've found a combination of parts that will work well together, and won't break apart at a stoplight.
