Multi viscosity oil question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2012, 06:24 AM
On 2 guys garage on TV they said that 10W30 oil is thin like 10W when cold and heavy like 30WT when hot. I've never heard this before----anyone else???
Old 05-10-2012, 06:31 AM
What they mean is, it won't get any thicker than 10 when cold or thinner than 30 when hot. It still thins out plenty as you know.
Old 05-10-2012, 09:50 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
5W30, 10W30,10w40-whatever the first number is, is the base weight-what they Oil Manufacturers use is called Viscosity Index Improvers (which are generally polymers)-here is a little bit on the subject:
http://www.machinerylubrication.com/...ndex-improvers
Which oil viscosity? Madmax305 Hotrodding Basics 4 02-18-2011 05:47 PM
71 Nova mono to multi leaf question. 1971 Nova Suspension - Brakes - Steering 5 12-05-2008 10:11 PM
Richmond 6 speed gear oil viscosity... AllenKarber Transmission - Rearend 0 05-24-2008 10:22 PM
Paint Viscosity Follow Up x711 Body - Exterior 14 12-01-2005 10:14 PM
Oil Viscosity And Bearing Clearance Relationships HJCHEVY400 Engine 9 04-16-2004 12:29 AM
