multimeter reading to high: Why? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2012, 08:34 AM
craftsmen digital multimeter reading 19 volts when should be 12. Not sure why the high reading
Old 03-11-2012, 08:46 AM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
you on the correct scale
Old 03-11-2012, 08:49 AM
delawarebill's Avatar
get another vom and compair
that is high for normal voltage.. but it just might be right too..
Old 03-11-2012, 11:43 AM
kc0kfg's Avatar
kc0kfg
What makes you think its the meter? I would check a known source or borrow another meter and use that to check the source that was showing 19v>12v.
It just be be your meter is right.
Old 03-11-2012, 05:29 PM
hign meter reading
Thanks for the reply but i had checked against known source and it reads high when check household current as well.
Old 03-11-2012, 09:05 PM
kc0kfg's Avatar
kc0kfg
Well if your house current is reading high as well I assume its reading above 126Vac that's whats allowed, I have seen as high as 130vac but its not common.
If your meter is out of range I think you have you answer already, buy a new one.
I just picked up a spare one from sears (well I had to go twice to replace the first one since it was broken out of the box)
Old 03-11-2012, 09:54 PM
multimeter reading high voltage
figured it out. It was to simple. The multimeter 9v battery was at 4.5 volts. when replaced with fresh battery brought the multimeter right back in range.
causes for high volt meter reading +16 ! wheel-7 Electrical 3 05-11-2008 05:13 PM
causes for high volt meter reading +16 ! wheel-7 Electrical 1 05-11-2008 06:42 AM
Reading OBD I codes with a multimeter kringold General Rodding Tech 6 06-06-2005 12:11 PM
