Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Multiple coats/too much paint
  #16 (permalink)
Old 07-31-2004, 08:35 PM
mitmaks's Avatar
mitmaks mitmaks is offline
Last journal entry: Grille
i like having 5-8 coats of clear coat cause ill wet sand whole car after its finished make it look straightest and smooth paint job. so it all depends on how many coats of what youre putting on, cause primer you can put 8 or whatever and youll end up sanding most of it off anyways till whole car is perfectly straight, base you usually need 3-4 to cover/hide
