Multiple engine ?'s HELP - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2010, 11:40 PM
ok so i need help identifying some pistons they're in a zz4 350 (4in. bore,1-piece seal), they are marked 321-00-16c ?
another, is boring .60 over on the same zz4 block ok on something that will rev to about 6500 and hopefully 550hp?
and last can a external balance setup be changed to internal balance?
Thanks Guys, as much info as possible will help.
Old 07-29-2010, 08:29 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That is a tall order for a streetable NA engine, IMO.
I'd probably use a solid roller cam, a lot of compression- using FT pistons and small chamber Dart or Brodix heads, at the very least a 750 CFM carb but 800-850 not out of the question, an intake to match all this- like a Victor, a hella-strong bottom end, stout valve train, etc.
This will take some real coin to do right, and if it was me, I wouldn't do it w/an OEM 4-bolt block in the first place.
Now, I expect to hear others say that an aftermarket block isn't needed @ 550 HP/6500 RPM. And that's fine- but I'd much rather spend the extra money on a good foundation than throw away a big chunk of change if/when the bottom end lets go and takes my forged reciprocating assembly w/it. And some will say a cast reciprocating assembly is fine, too. And maybe it is- it's just not what I would do, is all.
Now, depending on what it is that you hope to accomplish, there may well be other avenues to explore- like a bigger displacement (383 for instance) and a correspondingly milder camshaft to get you a ton of torque lower down than some high-winding 350.
An external balanced engine can usually be made into an internal balanced engine by using heavy metal (aka "Mallory" metal) to balance the reciprocating assembly.
Old 07-29-2010, 08:36 AM
And it ain't cheap
Old 07-29-2010, 10:46 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
why would you want to bore to 4.060 when if you need to bore it at all the most you would probably need to do it would be to 4.030. i'm not sure if you fall in this catagory but you see this alot where people want to bore the cylinders out the maximum they can to get extra power, and the truth is that just boring a SBC's cylinders out will barely give you a recordable power increase, you will need to stroke the engine as well if you want to see a power increase due to inceased cylinder volume (this is not always true with a BBC as you can bore them out far more than you can bore out a SBC)
and i agree with cobalt here that trying to make 550hp out of a ZZ4 short block would be risky, but i'm sure some have done it, but IMHO it would not be something i would be willing to try with my money, 450ish would be alot easier to obtain and more realistic for the given parts and it only being a 350. to get a 350 to make 550hp you will be hard pressed to do it with only turning 6500, 550 could be the peak at 6500 but then you will still need to go atleast another 500rpm before you shifted it to keep the power band up fromshift to shift, so you would be turning this engine 7000 (that is NA) forced induction and nitrous is a whole different story
Old 07-29-2010, 02:15 PM
Thanks for the answers guys! I agree and have made some new decisions...
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 11:22 AM
1985 C-6 truck tranny, no engine braking effect fast68 Transmission - Rearend 40 02-04-2008 06:55 PM
engine ?'s heavychevy70 Engine 4 02-01-2005 09:21 AM
67 Mustang Engine Stat ?'s 3-OnTheFloor Engine 2 12-20-2004 07:32 PM
