Muncie 3 speed - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 06-27-2007, 09:38 PM
Muncie 3 speed
I have a 70 Buick GS that came factory equipped with a heavy duty cast iron muncie 3 speed tranny
I cant seem to find any information on these tranny's. There's plenty of 4 speed info.
All Im looking for is decoding these #'s
GM3 3952646
B 240
Also these numbers are on a machined pad under the cover
H0C 19B
Any help appreciated
Quick reply to this message
Old 06-27-2007, 10:03 PM
Nevermind, I just found the info on a camaro site
Hopefully this info will help someone else out
tymdds
where:
t = transmission type
MANUAL AUTOMATIC
S = Saginaw 3-speed A = 68/69 L6 Torque-Drive
K = McKinnon 3-speed C = Cleveland Powerglide
H = 69 Muncie HD 3-speed T = Toledo Powerglide
R = 4-speed Saginaw B = Cleveland TH350
P = 4-speed Muncie X = Cleveland TH350
Y = Toledo TH350
y = model year (not calendar year)
m = month
Jan Feb Mar Apr May Jun Jul Aug Sep Oct Nov Dec
A B C D E H K M P R S T
dd = day of month
s = suffix
PowerGlide and TH350 (not used on all):
D = day shift
N = night shift
1969 Muncie 3-speed
B = 2.42 first gear ratio
1969 Muncie 4 speed only:
A = M20
B = M21 Use of the Muncie type suffix
C = M22 began with 21 Oct 68 production.
Examples:
R7S21 Saginaw 4-speed, Nov 21, 1966
P8R01 Muncie M2x 4-speed, Oct 01, 1967
P9T11B Muncie M21 4-speed, Dec 11, 1968
C9D14N PowerGlide M35 2-speed auto,
Apr 14, 1969, night shift
Old 07-28-2010, 07:34 PM
3 Speed Saginaw Transmission
I think i have a 3 speed Saginaw Transmission but not sure.
Numbers are as follows:
Left Side Cover GM 22-3952645
C 6 1
S 1 C 1 7 (serial tag)
Right Side:
GM 33
3925647
c 2 1
S11N556427
Tail
37 GM 3873886
Let me know what you think, is this a m22 rockcrusher 3 speed saginaw. The GM-22 on the side cover is throwing me off
Old 07-29-2010, 08:11 AM
That is a saginaw 3spd.
"Rockcrusher" transmissions (M22) were technically option code M22 for severe duty applications.
I'll spare you the boredom, just know that the only "Rockcrushers" are 4-speeds
Old 07-29-2010, 09:36 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
C 6 1
Right Side:
GM 33
3925647
c 2 1
S11N556427
Tail
37 GM 3873886
Gear's right.
From here:
Type- Saginaw 3-speed manual
Years- 1970-'72 ( C 6 1= March 6, '71)
Main Case- 3925647
Extension Housing- 3873886
Side Cover- 3952645
The "GM-22" is a foundry marking, most likely.
Old 07-29-2010, 02:41 PM
Praise from caesar...
I tell you when a guy buys parts for the "M22" he over-paid for...and I have to tell him its an M20...or worse a T10....oh man
Old 07-30-2010, 02:07 AM
ok thanks for the info, i actually got the entire transmission for free with the engine with 40000 original miles on it. Just trying to get info on these 3 speeds, i read that they were also in chevelles.
Not sure if these were the same type of gears.
Closed Thread
looking for a 5 speed daytona Transmission - Rearend 2 03-17-2006 05:44 PM
Suggestion on Muncie wide or close johken Transmission - Rearend 9 03-14-2006 02:12 PM
what all chevys came with a 254 Muncie 4 speed trans? tiresmoke55 Transmission - Rearend 6 02-07-2006 10:20 AM
4 speed muncie 79 camaro 454 Electrical 2 05-19-2004 03:44 AM
Turbo 350,Turbo 400,700R4,Or Muncie 4 Speed nightrain_rod Transmission - Rearend 2 04-18-2003 12:35 PM
