Muncie 3 speed. How much? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2010, 09:54 PM
Grunt
I was wondering what a MC-1 Muncie is worth. From what I can tell by the numbers it is a 71. I found a guy that wants to do some trading for one I've had. Thanks.
Old 03-11-2010, 11:10 PM
MI2600's Avatar
Member# 3287
If this is the Chevy HD Muncie, 3-speed, I bought two of them at the local junkyard for $15 each. I made one good one from the two.
These were made on two different gear ratios. If memory serves, there will be an "A" or a "B" stamped on the case below the side plate. The A has about a 3.11 first gear and winds up in a heartbeat. The B is about 2.5 and is what I wanted.
Old 03-16-2010, 02:19 AM
Not really worth much. Check Craigslist or Ebay.
Muncie 4 speed transmission hotchevellechick72 Transmission - Rearend 2 02-27-2010 09:25 PM
cosmichrome drchip Hotrodders' Lounge 19 12-28-2009 05:33 PM
what all chevys came with a 254 Muncie 4 speed trans? tiresmoke55 Transmission - Rearend 6 02-07-2006 10:20 AM
4 speed muncie 79 camaro 454 Electrical 2 05-19-2004 03:44 AM
Turbo 350,Turbo 400,700R4,Or Muncie 4 Speed nightrain_rod Transmission - Rearend 2 04-18-2003 12:35 PM
