Muncie 3 speed trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2013, 10:32 AM
Please someone help me id a muncie 3 speed trans so I can buy the right rebuild kit.
Main case: GM 1 F 120 8852 882
Tail case : GM 2 3911984
Side cover : GM 1 3952646
Not sure if its a M 20, M 21, OR M 22 !
Thanks !
Old 09-01-2013, 10:56 AM
carolinacustoms's Avatar
Automotive Extraordinaire
Are you sure it is a muncie? If it is a three speed muncie it will be a M62 or M64, the M20, 21 and 22 were all 4 speed. Maybe a few pictures would help someone with a little more knowledge to identify it for you. I am not sure but I think the muncie would also be an aluminum case where as a borg warner or saginaw would be a cast iron case.
Kelly
Old 09-03-2013, 07:02 AM
Post a picture; but it sounds like you have the old muncie 3spd from the 50's. As Kelly said; the M20,21 and 22 are all aluminum cased 4 speeds.
If all you need is the ratios; theres no guarantee that what the General put in that case 50yrs ago, it exactly whats in there after 50yrs of service and owners. Your easiest answer is to put the trans in 1st gear and turn the OUTput shaft 10 times, and count the number of times the INput turns. then divide that number by 10. There may be enough slop in the transmission that you wouldn't be able to find the difference between 2.4 and 2.7 for example by only turning it once. Hence the "10 times" method; it'll cancel out most of the slop. Do this for all your forward gears and you'll have your ratios.
Definitely post a picture
Old 09-11-2013, 03:12 PM
muncie 330 3 speed trans
where can I find a rebuild kit for muncie 330
kit #CT-BK289 ?
Old 09-11-2013, 07:04 PM
RWENUTS's Avatar
Google it! It takes 10 seconds.
Muncie 330 (3 Speed (Rwd), Bearing Kit [CT-BK289] - $173.99 : Automatic, Standard Transmission and Transfer Case Rebuild Kits, Cobra Transmission Parts 1-800-293-1848, Cobra Transmission
Old 09-12-2013, 09:54 AM
Ive tried them all !
I tried cobra and a couple others, they all say there out of stock on kit CT-BK289 and dont know when theyll get any more. thats why I ask for help at this forum, but thanks anyway !
Old 09-12-2013, 10:30 AM
RWENUTS's Avatar
Could try these guys if you haven't already! THey do muncie 4 gears. Might have parts.
Muncie Trans
Muncie 4 Speed 400smb_s10 Transmission - Rearend 11 07-28-2012 08:06 AM
Muncie 3 speed FN2XLR8 Transmission - Rearend 6 07-30-2010 02:07 AM
muncie 4 speed trans setup 55 chevy rebuild Transmission - Rearend 5 07-02-2006 10:22 PM
what all chevys came with a 254 Muncie 4 speed trans? tiresmoke55 Transmission - Rearend 6 02-07-2006 10:20 AM
Muncie 4 speed ActionJackson Transmission - Rearend 1 11-20-2002 08:05 AM
