Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - muncie 318 3 speed w/o overdrive questions
Old 03-23-2013, 01:10 PM
junior stocker's Avatar
junior stocker junior stocker is offline
Technically, it's a 319 trans with the OD unit attached. And they are weak as already noted. Hurst USED TO make a shifter for them, no more, and finding a used one is difficult; everyone is looking for them. You could probably adapt a shifter if you have any fab skills; it's the position of the solenoid that complicates everything. You might want to think about using the retooled MOPAR 833-A 4-speed used in some Chev/GMC trucks; that trans was redone to make 4rth gear overdrive, and Hurst does make a shifter for them. Butch/junior stocker.
