Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - muncie 318 3 speed w/o overdrive questions
Old 03-23-2013, 03:06 PM
junior stocker's Avatar
junior stocker junior stocker is offline
Originally Posted by junior stocker View Post
Technically, it's a 319 trans with the OD unit attached. And they are weak as already noted. Hurst USED TO make a shifter for them, no more, and finding a used one is difficult; everyone is looking for them. You could probably adapt a shifter if you have any fab skills; it's the position of the solenoid that complicates everything. You might want to think about using the retooled MOPAR 833-A 4-speed used in some Chev/GMC trucks; that trans was redone to make 4rth gear overdrive, and Hurst does make a shifter for them. Butch/junior stocker.
You might want to try contacting "Little Wing" over on JalopyJournal.Com/the HAMB. She deals in a lot of discontinued and used Hurst items; she may have the mount needed for a Hurst shifter on the 319 OD trans. Butch/junior stocker.
