Hotrodders Bulletin Board
#1
Muncie 4-Speed
I am currently running a Muncie 4 speed with a zoom stage 2 street strip clutch and a gmpp flywheel. I am thinking about going with a TH-400 with a shift kit. My questions are do you think it would fit with my driveshaft or would I probably need to get another one? Also what all would I need? I found someone who has a th400 short tail shaft, 3000 stall, aluminum deep pan, hurst pro-matic shifter but I don't know if I need anything else or how much of a pain this would be. Any help would be appreciated!
#2
Muncie 4-Speed
just a yoke and shifter and coolant lines , and radiator that has the outlets for trans lines
#3
driveshaft would be the same length and spline as a 350 turbo, 400 turbo has a shorter driveshaft and different spline.
#5
why change?
Just curious - why would you want to give up the muncie 4 SP for the automatic?? Most folks want to go the other way? I have a THM 400 in my 68 Corvette - and would love to have the 4SP instead. Banging gears is much more fun
#6
why change? I had a pressure plate explode (no scatter shield) on me in 1974. It cut the brake lines , broke the throttle & distributor, cut the trans tunnel open from one side to the other. That started me on my path of automatics transmissions. Some cars do need a manual trans.. a Corvette is one of those cars ......... IMHO
At the Bonneville Salt Flats... 130mph is known as First gear ............... |
#7
aw, autos blow up, too. weinie.... don't they? anyway, it's cheaper to puke an auto than a muncie, i think you'd better send it to me, i'd pay shipping |
#8
ok... you got me there tomslik; a 700 trans photo: ![]() ![]()
#9
Mostly because I am going to put a pro charger on it this winter and with the motor being 700-800 hp at the wheels I think an auto with a shift kit might be a little better for it. Then again I don't know for sure right now because since this car will spend 95% of its life as a street car a 4 spd on the street is alot of fun
#10
An Overdrive automatic would be nice such as a TH2004R or TH700R4 but would cost $$ to make it live behind 800HP. The TH400 will be much cheaper to build for that power level. For a strong 2004R check here, he's in Ohio.
Vince Janis Janis Transmissions 1507 Kenmore Blvd Akron Ohio, 44314 1-330-753-6609 |
#11
Also if you'd like to check out a bunch of Trans Gurus spilling TH400 building secrets look here.
http://www.turbobuick.com/forums/tr...d-pictures.html |
Back to top |
Similar Threads for: "Muncie 4-Speed"
| looking for a 5 speed | daytona | Transmission - Rearend | 2 | 03-17-2006 04:44 PM |
| Suggestion on Muncie wide or close | johken | Transmission - Rearend | 9 | 03-14-2006 01:12 PM |
| what all chevys came with a 254 Muncie 4 speed trans? | tiresmoke55 | Transmission - Rearend | 6 | 02-07-2006 09:20 AM |
| 4 speed muncie | 79 camaro 454 | Electrical | 2 | 05-19-2004 02:44 AM |
| Turbo 350,Turbo 400,700R4,Or Muncie 4 Speed | nightrain_rod | Transmission - Rearend | 2 | 04-18-2003 11:35 AM |
