Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Muncie 4 speed
Thread: Muncie 4 speed
Old 09-11-2011, 06:02 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
Yes, you will need a later flywheel.....snout on the 1 piece sael crank is different than the 67 one....
As for the tranny, if you are going with the steeper gears, go with the M21.....If staying with a highway gear, the M20 would be better as it has a wider gear ratio in the gears.
