Muncie 4 speed
How much HP will a Muncie 4 speed hold. How do you distinguish between an M21 and an M22. The M22 is what they called the "rockcrusher" right? Is that the better trans. Want to put this behind a 648 hp blower motor, My gramma drives an auto, I just want to have fun!
There ARE aftermarket parts available to make a Muncie strong enough to deal w/it, and there are other trannys altogether that might be a better choice like a Tremec 6-speed (RPM Performance, Finishline Transmission, The GearBox, D&D Performance have been mentioned on this board for Tremec 6-speed performance builds). I'll leave it to AutoGear and any other members that may have more info for you on this. Input shaft rings and other clues can help to determine a close ratio from a wide ratio from a 'crusher, but the best way to tell is to pull the side cover to see exactly what you have- gears can and often are changed during the life of a transmission, especially one as old as the Muncie. You can google "muncie identification" and get more info. |
Muncie
Thanks for the info. I also have a TH400 (it's for sale on this site). I guess from what I hear that it can handle hp even in stock trim. I got a heck of a deal on this motor but it sounds like it's really going to cost me in the long run. A Tremec 6 speed would be nice, ya know anyone that has one laying around .....cheap? I also need to beef up the rear end. Looking for a ford 9 inch too. I've had this Muncie laying around for years and thought it would be fun (like back in the 60's).
For what muncie's are bringing & what you'll get for your 400 , you'll be better than 1/2 way to a tremec !!??
dave |
One of our friends/customers has a '65 GTO he drag races. In the earlier days, he used the Muncie. By the time power levels got beyond 500 HP and 500 lb. ft., the "little" Muncies (M-20 & 21) were proving to be not up to it. Tried an M-22 (large output shaft, TH-400 "yoke") for a while. They too, cracked the cases. Liberty gears and a steel mid-plate helped, but never got a whole season out of it. He runs a Jerico now. But this is a fairly heavy car with a high-torque Pontiac in it. It 60'-s in the 1.4s and goes 10.30s right around 130 consisitently. That's asking a LOT from a "stock" transmission.
Many of the T/A crowd use the Tremacs. The Kiesler "kits" are very popular. For a "drag" application, not the better choice. For a FUN street car, the 900 should take the power. Another 4-speed option that can take as much as the Muncies is the Borg Warner ST-10. I like the older iron-case version better for drags. But a good, tough trans. NOTE: My knowledge and experience with the Muncies and the "partculars" is strictly from the '70s and early '80s when they were still plentiful in cars. I can't "swear" to all the correct designations, just what we were calling them "back in the day". Best recollection follows: Earlier versions were around, but rare. These are the "popular" ones beginning around '63 (I think)... I've seen a few from Bonnys and Catalinas with the "long tail". Odd-looking... M-20 "wide ratio", usually behind bigger engines in heavier cars with "normal" gearing 2.56:1 1st (?) M-21 "close ratio", usually in cars with high-powered engines and "stiffer" gearing. 2.20:1 1st M-22 came in both configurations ("close" and "wide" ratios), upgraded gear quality and larger output shaft. Later muscle cars. M-37 "Super Muncie" or "rock crusher" Several ratios available, large input shaft (1 1/4, like "Hemi" 4-speed and "big" Top Loader), spur-cut 1st gear (increased load "shock" capability, makes a horrid "whine", thus the nickname) and large output shaft. The only cars I recall them in were the ZL-1s. LOTS sold over the counter for racing in the '60s. If someone reading this has more specific detail on this one, I'd really like to know more. Most of my Muncie work was in Pontiacs. Some of the designations, gear ratios, etc. are different with the Chevy versions, but for the most part, they're "the same", as are the Buick and Olds. I recall Pontiacs have the speedo drive on the left and at least some Chevys, they're on the right. There's an Italian-made version of the M-22 available "new" today. They call it "Super Muncie". Reports are favorable, but I have no "hands on" with it. A search would turn up a vendor. For a "road car", I prefer the "fine" spline. 26, I think. For a drag car, the "course" (11) has greater "shear" strength. FWIW Jim |
Muncie
Thanks for the input. This motor kinda fell in my lap, looks like it could be fun, BUT I'm on Uncle Sams dime and not a lot of extra coin. Trying to use what I have until whatever weak link breaks, then fix as you go. It would be nice to build a car 100% right out of the box but time and funds are a restricting factor. Just getting that monster running in my garage IN THE CAR gives me wood thinking about it. This has never been together before. I don't know if I've posted this but I picked up a '41 Chevy car frame that has a mustng IFS in it already and the frame is square. The stock truck frame is a "C" channel would have needed something (IFS, clip, whatever and the frame boxed). This saved a lot of work and I'm going to cage it and add reinforcenment. Needs all new wiring, and interior, and, and, and, MONEY. I can only go from there. A 4 link, roll cage, Tremec, ford 9 inch are like sugar plums dancing in my head.
The point is, you can certainly use a stock Muncie M20/21/22 to get the vehicle up and running. While the straighter cut gears of the close ratio M22 are stronger than the wide ratio M20 or the close ratio M21, w/a blower motor you don't need a close ratio box to keep the engine in the power band- you'll have a wide-as-the-Mississippi powerband as it is, and to use a close ratio box necessitates a lower (higher numerically) rear gear so there's not excessive clutch slippage in first to get underway. The lower rear gear ratio also means a faster driveshaft RPM and more engine RPM at any given cruise speed on the highway, and that gets old fast. That leaves you needing an aftermarket wide ratio gear set and the other goodies that are available to beef up the Muncie, or an OD manual. It's up to you to determine which way to go, but like I said, for now you can use the stock box if you take it real easy on it. As for the TH400, it can be made to handle a lot of HP, so can the TH350 and Powerglide for that matter. But if you have your heart set on a manual...
Muncie replies
Thanks for taking the time to repond to my inquery. I have a long way to go on this as none of this stuff has ever been together. Thinking about a front motor plate to secure this motor and add some rigidity to frame. I have pics of other frames and the way guys have strengthened them. I'm new to street rod building but have built a few ground up Harley choppers (wanna buy one?). I could get some good stuff with that money. LOL I have a couple of projects blocking my garage that I have to get out of the way. I'm sure you haven't heard the last of me yet. I should post some pics as maybe I'll get more helpful input from you guys.
I've posted this a few times; one more can't hurt. As said, the M22 has straight-er cut gears, not straight cut gears.
No telling how many times someone has passed up a M22 because the gears weren't straight cut...
Trans responses
Thanks for the comments and info. Haven't had much time to work on project lately with spring yard work and all. May just "go for it" with what I've collected over the years while I'm still young enough to do it (65). Buncha work that has to happen to get this running as is. As I've said, never done a ground up on a car so have a learning curve. Too bad there wasn't somebody in the area (Oswego, IL) looking for a garage buddy to hang out with so I could pick his(her) brain. Later
Slapz, I'm in ottawa [about 45 min] P.M. me , maybe I can help.
dave |
| Muncie 4 speed | DanBoyd | Transmission - Rearend | 11 | 09-14-2011 11:26 PM |
| Muncie 3 speed. How much? | 1lowz | Hotrodding Basics | 2 | 03-16-2010 02:19 AM |
| 4 speed muncie??? | 350olds | Transmission - Rearend | 4 | 03-11-2007 01:19 PM |
| 4 speed muncie | 79 camaro 454 | Electrical | 2 | 05-19-2004 03:44 AM |
