-   -   Muncie 4 Speed (http://www.hotrodders.com/forum/muncie-4-speed-221082.html)
400smb_s10 06-27-2012 07:28 PM
Muncie 4 Speed
I have a Freshly rebuild Muncie 4 speed and I was wondering what It would be worth....
Sorry about the post in this forum but I wasnt sure where to put it
Thanks
Ed
RWENUTS 06-27-2012 07:54 PM
M20, M21 or M22
Big difference in sale price.
warren57 06-28-2012 07:27 PM
Muncie
I just had an M-20 gone through. The original trans cost $500 (was supposed to be good!) After 3 new gears, slider and rebuild parts, it cost me $800.
So I have $1300 in mine. Not sure you could get by much cheaper. Most so called rebuilts are selling between $1000 and $1600.
Way to much considering you can buy a new 5 speed around $2000.
1971BB427 06-28-2012 07:48 PM
Not much difference between an M20 and M21 in price, but an M22 will be quite a bit higher.
AutoGear 06-29-2012 10:57 AM
M21's are hard to sell unless its for a resto job. The M20 will work better with more highway friendly axles like 3.73s 3.42s and 3.31; and the M20 shares the same 1st, 2nd, 3rd gears and reverse geartrain. The difference is in the cluster and input (maindrive) of the 20/21.
The M22 does NOT have spur gears, however the only common gears it shares with the 20/21 family is the mainshaft reverse gear and the splined idler gear. All the other gears are M22 specific
Things buyers want to know:
Input Splines / Output Splines?
damage to case?
new wear parts?
7/8" or 1" countershaft?
Gear Ratios?
Whats it work best with?
If I had a non-numbers matching M21; I would rebuild it as an M20 because it fits a wider range of cars and its probably easier to sell
lmsport 06-29-2012 11:55 AM
M-20 M-21
1st 2.52 2.20
2nd 1.88 1.64
3rd 1.46 1.28
4th direct direct
Put trans in 1st and turn output 10 revs, count input revs to determine ratio.
AutoGear 06-29-2012 01:05 PM
Aside from the ultra numbers-matching lunatic fringe; Id say 800 and up to probably 1200. If it was freshly rebuilt with a warranty; you could get 1800 depending on options
And NO 26 spline input/ 32 spline output is NOT an M22
the spline change from 10/27 was YEAR specific, not MODEL specific
400smb_s10 07-02-2012 08:50 AM
where would i find the numbers on the tranny to find out what it would be?
warren57 07-02-2012 11:55 AM
Muncie
2 Attachment(s)
I attached photo's
http://www.hotrodders.com/forum/atta...1&d=1341251521, although they are a little hard http://www.hotrodders.com/forum/atta...d=1341251694to see.
Hope this helps.
327NUT 07-02-2012 01:35 PM
Sorry to hijack...but in the old days the story was you could tell an M22 (w/o pulling the side cover) by the big drain plug on the right side. Then I heard that all over the counter 4 spd. cases had the drain plug.....which is true. By the way I was building a 355" sbc for my 240Z back in '79 and bought a REAL M22 from a guy for $50, he had wrecked his 70 1/2 Z-28 and was hurting for $$$$. I sold it the next week for $450....BIG money back then.
warren57 07-02-2012 06:16 PM
I know. About 10 years ago I bought a 71 Z-28 that ran into the back of another car at low speed and wrinkled a fender and broke the grill. It had about 60K miles and I bought the whole car for $1,000 and put the running gear in a 39 Ford coupe.
These things are way over rated and over priced these days.
I had a T-10 in a 56 years ago and it was fine. Very strong, I really believe just as good as a Muncie and you can still pick them up fairly cheap.
I guess the days of picking up old 4 speeds for $100-$150 are gone... along with $.32 gas and $.25 Cokes!!!!
I think I like the old days better....
Psylosyfer 07-28-2012 08:06 AM
Have new pro built thm 400 w/ new 2000 Stall conv.
Thanks
Ed
I have a pro-built rated 600hp, th400, *******************************
Interested?
