Muncie
I just had an M-20 gone through. The original trans cost $500 (was supposed to be good!) After 3 new gears, slider and rebuild parts, it cost me $800.
So I have $1300 in mine. Not sure you could get by much cheaper. Most so called rebuilts are selling between $1000 and $1600. Way to much considering you can buy a new 5 speed around $2000. |
Not much difference between an M20 and M21 in price, but an M22 will be quite a bit higher.
M21's are hard to sell unless its for a resto job. The M20 will work better with more highway friendly axles like 3.73s 3.42s and 3.31; and the M20 shares the same 1st, 2nd, 3rd gears and reverse geartrain. The difference is in the cluster and input (maindrive) of the 20/21.
The M22 does NOT have spur gears, however the only common gears it shares with the 20/21 family is the mainshaft reverse gear and the splined idler gear. All the other gears are M22 specific Things buyers want to know: Input Splines / Output Splines? damage to case? new wear parts? 7/8" or 1" countershaft? Gear Ratios? Whats it work best with? If I had a non-numbers matching M21; I would rebuild it as an M20 because it fits a wider range of cars and its probably easier to sell |
Aside from the ultra numbers-matching lunatic fringe; Id say 800 and up to probably 1200. If it was freshly rebuilt with a warranty; you could get 1800 depending on options
And NO 26 spline input/ 32 spline output is NOT an M22 the spline change from 10/27 was YEAR specific, not MODEL specific |
Muncie
I attached photo's
http://www.hotrodders.com/forum/atta...1&d=1341251521, although they are a little hard http://www.hotrodders.com/forum/atta...d=1341251694to see. Hope this helps. |
Sorry to hijack...but in the old days the story was you could tell an M22 (w/o pulling the side cover) by the big drain plug on the right side. Then I heard that all over the counter 4 spd. cases had the drain plug.....which is true. By the way I was building a 355" sbc for my 240Z back in '79 and bought a REAL M22 from a guy for $50, he had wrecked his 70 1/2 Z-28 and was hurting for $$$$. I sold it the next week for $450....BIG money back then.
I know. About 10 years ago I bought a 71 Z-28 that ran into the back of another car at low speed and wrinkled a fender and broke the grill. It had about 60K miles and I bought the whole car for $1,000 and put the running gear in a 39 Ford coupe.
These things are way over rated and over priced these days. I had a T-10 in a 56 years ago and it was fine. Very strong, I really believe just as good as a Muncie and you can still pick them up fairly cheap. I guess the days of picking up old 4 speeds for $100-$150 are gone... along with $.32 gas and $.25 Cokes!!!! I think I like the old days better.... |
Have new pro built thm 400 w/ new 2000 Stall conv.
Interested? Last edited by Crosley; 07-28-2012 at 08:32 AM. Reason: no sales or trades on open forums |
| Muncie 3 speed. How much? | 1lowz | Hotrodding Basics | 2 | 03-16-2010 02:19 AM |
| 4 speed Muncie Help ?? | super_silent | Transmission - Rearend | 14 | 11-22-2007 07:38 AM |
| I need a Muncie 4 speed | blown64corvette | Transmission - Rearend | 6 | 11-12-2004 08:21 PM |
| Muncie 4 speed | ActionJackson | Transmission - Rearend | 1 | 11-20-2002 08:05 AM |
