muncie 4 speed ID - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 08-21-2004, 05:18 PM
friend's Avatar
New Member
muncie 4 speed ID
Hi, I'm new. First posting. I'll give it a whirl. I have a 1970 GMC 4X4 pickup with a 4 speed. It looks like a muncie 4 speed from all the pics but there's no numbers where the say to look. Only pass. side numbers are D156 with a circle at each end. under that number 12. then GM under that. and finally the number 6273212 at the bottom of the list. To the left of this is a circle of dots about the size of a quarter with a line threw it. Thanks, John
Old 08-21-2004, 05:54 PM
TL-Iguana's Avatar
Can't say for sure what you have without more information, but I'm 99% confident this is it.
Muncie SM465
(shown without extension housing)
Top loaded heavy-duty 4-speed transmission with cast iron case, extension housing and shift tower. Synchronized in 2nd, 3rd, and 4th. Available in 2wd and 4wd drive versions. Cases have PTO openings on both sides. 1st and reverse gear are non-synchronized. 1st gear is a deep reduction low gear and shift knob may show H pattern with Low, 2,3,4. Used in GMC and Chevy trucks and stripped chassis from 1968-85
The Lone Iguana
Old 08-21-2004, 05:56 PM
TL-Iguana's Avatar
If it doesnt show up, check out http://www.motivegear.com/tech_info/...nny_guide.html and scroll down to the SM465 listing.
