muncie 4 speed issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2012, 07:04 AM
kool kat's Avatar
I have a four speed that is making a howling noise at idle. was a fresh rebuilt by a well known trans. shop when installed. about 1500 miles on it now. it was shipped in a crate, and dropped. front shaft went thru the plywood container. seemed ok inside and out but after 4 years it developed a squeel until you let the clutch out. first thought was a throw out bearing and replaced. noticed pilot shaft had alot of play in it. have never taken apart a tranny, does this sound like bearing issues? trans. works in all gears and is quiet running until you push the clutch in.
Muncie 4 speed DanBoyd Transmission - Rearend 11 09-14-2011 11:26 PM
Muncie 4-Speed Geradmg Transmission - Rearend 10 07-14-2008 11:20 AM
muncie 4-speed jake_arcticcat Transmission - Rearend 3 06-19-2008 08:34 AM
4 speed muncie 79 camaro 454 Electrical 2 05-19-2004 03:44 AM
