muncie 4 speed sticks in first think it may be linkage - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2012, 08:01 PM
just got a 63 impala that has a supposed recent rebuild on a muncie 4 speed. It hung up in first and after messing with linkage it goes in reverse but freezes and wont go in forward gears. not sure if linkage is lined up properly. it did shift fine through all gears only got about 3 miles on it. I may have linkage messed up a picture of proper alignment may be helpful. thanks
Old 09-16-2012, 10:01 PM
RWENUTS's Avatar
What shifter?
Take a pic of the linkage for us!!
Old 09-17-2012, 07:02 AM
Wiki Edits: 27
shifter adjustment
with the trans in neutral , Un hook the rods from the trans shift arms, move them back and forth one at a time to check for the spring loaded ball to click into the internal notch. leave both main case levers in neutral and make sure reverse lever is in neutral , then you use the solid shank end of a 1/4 in drill bit to go thru the holes in the shifter body and the holes in the shifter arms. Adjust the shifter rods to align with the holes in the trans arms. remove the drill bit. If everything is dirty you should dissasemble and clean, and lub it first. . I don't think the 63's used a rubber dirt shield on the shifter mechanism.
Old 09-17-2012, 07:10 AM
Wiki Edits: 27
Rebuilt right. ?
In a rebuild they might have lost one of the balls and the spring could be hanging on the rooster comb. WE used to take out the spring and carefully fit a solid piece of 1/4 in drill rod between the 2 balls. On a hard power shift the inertia of the parts would go past neurtal compress the spring and you would be trying to be in 2 gears at once
Old 09-17-2012, 08:03 AM
Timothale gives good advice. You could also have a cracked fork (We just opened a customers box and took one fork out in 4 pieces - pin, both tips and the saddle area woof!!) Your sidecover could be cracked and flexing as well; but I believe Timo has you on the right track.
four speed hung up, muncie
Muncie 4 Speed 400smb_s10 Transmission - Rearend 11 07-28-2012 08:06 AM
Muncie M20 linkage placement mmisch Transmission - Rearend 2 02-08-2010 04:33 PM
Muncie 4-Speed Geradmg Transmission - Rearend 10 07-14-2008 11:20 AM
muncie 4-speed jake_arcticcat Transmission - Rearend 3 06-19-2008 08:34 AM
Muncie 4 speed ActionJackson Transmission - Rearend 1 11-20-2002 08:05 AM
