muncie 4-speed tranny questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2006, 06:58 AM
ok here`s the inside scoop i bought a used th-350. installed it had a driveshaft made. everything hooked up new filter and gasket. went to take off didn`t want to go into gear.Later finding metal particles in the oil. instead of rebuilding the tranny gonna try and swap trannys, and i was wondering what yoke the muncie uses, is it possible i could use the same drive shaft as the automatic with the 4 speed or do these 4 speeds have a solid mount driveshaft with a slide yoke assembly on the tail end of the shaft? i`d apreceate the help. thnx
Old 06-24-2006, 07:25 AM
Unless your Muncie is one of the rarer M22 "rockcrushers" ,the TH350 yoke will fit. I think the "block to end of shaft" lengths of the Muncie and TH350 or close enough so that the complete driveshaft assemblies will interchange.
Bob
Old 06-26-2006, 12:13 AM
Sometime in the very early '70s, they went to a larger yoke on the Muncies. My old Muncie was a '68 model, and it used the same yoke as a T-350, PG, 3-peed stick, etc.
If your T-350 has the 6" tailshaft housing, it should be the same length as the Muncie (with bellhousing), within a fraction of an inch.
Old 06-26-2006, 05:21 AM
Last journal entry: PICTURE TEST
trans
Muncie rear splines came in 2 flavors,,,,28 spline and 32 spline, As Jim pointed out the 32 spline came out in the 70 model year...
The chances are good you have the 28 spline transmission, if so it's a direct bolt in with the 6" tail th-350
Keith
Old 06-26-2006, 11:14 AM
RippinRon's Avatar
I believe it was the super t-10 that used the th400 yoke.
Old 06-27-2006, 09:45 PM
what kind of tranny came in the 55 chevy 2 door hardtop?
with a the 265 i think it is. it has a 4 speed.
Another question - " anybody know what horsepower rating thay can handle?", " What tranny came in the 4cyl. svt mustang ? it has a cast iron bellhousing , and it also has a rear mount shifter ,. The tailshaft section is aluminum. it`s just a curiousity. does anybody need anyparts for trannys? got a bunch of em taking up some storage space. 2, 3 speeds one car one truck. sm-465, sm-462, mustang 4 speeds x2, automatic th-350. oh and a Ford e.f.i. 302, 89 model with a c-4 tranny? sorry got a thing for the non-gas milage friendly gear ratios.just love the top end pull hehe
Old 07-03-2006, 05:21 PM
fast68's Avatar
likes chevy trucks & boobies
it was 27, not 28..
and sm462 did not exist
i think you mean sm420
id love to get ahold of the two top loader Gm truck trannies you have, but youre in puerto rico, so thats impossible lol
if thats really what trannies you have
hmm
good luck
Old 07-03-2006, 09:28 PM
muncie
well yes they are he sm-465 and the sm420. but the sm420 has a broken top housing, i got it from a dump they had ran over the truck and snapped off the shifter lever. but i got it just in case parts would interchange.
you mean as in sm465 large ribbed case. weighs nearly 200 lbs. and the 420 is a smaller non ribbed . one has a higher gear than the other. oh and i have a set of three speeds a siginaw and a muncie 3speed. just kinda found those on the side of the road. the "old guy" said they were locked up.. hehe lucky for me i took the front shaft with an old clutch and turned it over hehe. that`s where it stood. never found a shifter. plus the lil trannies don`t look too appealing."sheer deficiency of size" I do`nt think they would hold up.
More BG Speed Demon questions Jacks77 Engine 21 08-18-2005 04:58 PM
Cost of a rebuilt Muncie 4 speed Chevy21 Transmission - Rearend 1 12-09-2004 06:16 PM
Tranny fluid and stall converter Questions 406chevelle Transmission - Rearend 5 06-09-2004 04:28 PM
Muncie tranny question cabrio Transmission - Rearend 3 10-02-2003 12:17 PM
Tranny Rebuild Questions ericsdad Transmission - Rearend 1 02-02-2002 06:47 AM
