We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 07-29-2005, 02:41 PM
bonuts's Avatar
bonuts bonuts is offline
Got Ouzo for touzo
Muncie 4 speed trouble
When under power my Muncie M22 pops out of first gear, any suggestions as to the problem?
I was planning on doing a complete rebuild but after seeing the prices I think I'll just try to fix the only problem it has instead. The new project is going to cost a bundle and I figure this may be one way to save a bit.
bonuts
Old 07-29-2005, 05:50 PM
sedan delivery's Avatar
sedan delivery sedan delivery is offline
transmission
under the synchronizer sliders there are three small rectangle shaped pieces, if these are worn and the slider is worn this can happen. the small pieces are called shifting plates. also if the pilot bushing is worn the movement of the input shaft, will cause it to come out of gear. any worn bearings can also cause the problem. you really can not tell without a disassembly and inspection.
Old 07-29-2005, 08:39 PM
56Maynard 56Maynard is offline
A small parts kit isn't gonna cost much. It will provide all the bearings, gaskets, thrust washers and junk you'll need. If you need shift forks or sliders, they dont cost much either.
the first thing I'd do is knock it into first with the engine off, and then remove the 1st/2nd shift tab from the shift post on the side cover and then take a small cresent wrench and see if you can shift the post further into gear with the wrench. If it does go further into gear, you simply have an out of adjustment linkage arm. Shorten it until the shift tab lines up with the shift post flat spots.
If you eliminate linkage adjustment from being the problem, pull it out for a rebuild (you can do it yourself).
The best way to save money with a tranny is to replace bearings, sliders, and forks as needed before worn parts fail and break good parts. It gets real expensive quick when a $0.02 bearing eats a cluster gear.
Old 08-01-2005, 12:00 PM
k-star k-star is offline
trans
Look at the shifter...if you have a compitition plus style shifter, There are 2 stop bolts on the front and rear of the shifter..... The one towards the front of the car controles 2nd and 4th.... the one at the rear controles the 1st and 3rd... this is the one you want to back off,, try 1 full turn and see if it helps......
Keith
K-Star Automotive
Performance Engines
It's better to have a gun and not need it, then need a gun and not have it.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Muncie 4 speed trouble"
muncie 4 speed trans setup 55 chevy rebuild Transmission - Rearend 5 07-02-2006 10:22 PM
65 Vette - Trouble with Muncie 4 speed AMS3 Transmission - Rearend 10 12-16-2005 03:32 PM
Cost of a rebuilt Muncie 4 speed Chevy21 Transmission - Rearend 1 12-09-2004 06:16 PM
I need a Muncie 4 speed blown64corvette Transmission - Rearend 6 11-12-2004 08:21 PM
muncie 4 speed ID friend Introduce Yourself 2 08-21-2004 05:56 PM
