muncie 4spd Hydraulic throwout - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2010, 06:38 AM
streetrodderbn's Avatar
Certifiable Streetrodder
I'm putting together a 1935-40 ford chassis with a muncie m20 tranny and am interested in finding out how to install (and how expensive) a hydraulic throwout bearing . I have the stock pedal assembly from a 39 ford and have adapted power brakes to it, but the mechanical linkage for the clutch linkage is giving me fits! I need to bleed the brakes to see how far the pedal travels to see if I will hit the throwout arm!! I have never installed a hydraulic system,and need info!! Or, if anyone has put a 4 speed in a 35-40 ford chassis with mechanical linkage I need pics!!
Old 11-22-2010, 09:27 AM
Ive never personally used a Hyd T/Out Bearing in a street application. We have had customers use a HTOB setup however, so I'll call around, but you'll be better off getting 1st hand experience.
What bellhousing are you using?
Old 11-22-2010, 09:39 AM
Last journal entry: headers
we ran this 1 in a race car
http://www.speedwaymotors.com/Ram-St...evy,29140.html
worked very well came with instructions. you will still need a master cylinder and some fittings/line. so i would estimate it to cost around $225.00 for everything.
Old 11-22-2010, 04:35 PM
thanks, I'm using a 621 bellhousing with an 11' clutch.
TKO 600 Hydraulic Throwout Bearing SnottyAust Transmission - Rearend 10 09-16-2010 03:13 AM
sbc bellhousing for hydraulic throwout streetrodderbn Transmission - Rearend 2 05-27-2010 12:56 PM
Muncie 4spd Question MAD BOWTIE Transmission - Rearend 4 08-09-2007 06:08 PM
clutch slave cyl vs hydraulic throwout brg BOOKS4CARS Transmission - Rearend 19 01-27-2005 01:15 PM
t-10 vs Muncie 4spd Hollywooding Transmission - Rearend 11 06-21-2003 08:23 AM
