Muncie - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2006, 06:43 PM
south65ss's Avatar
Muncie
Are all Muncie 4 speed transmission cases made of aluminum or are there any of iron ?
Old 04-22-2006, 07:02 PM
BOBCRMAN@aol.com's Avatar
Muncies (non Truck) are all aluminum.
Old 04-23-2006, 03:46 AM
If you find a GM 4 speed from the 60s with an iron case & tailhousing it's a saginaw, iron case/alloy tailhousing it's a BW t10 (super t10s were all alloy too but clearly marked Borg warner and had 9 side plate bolts instead of 7 on Muncies).
Suggestion on Muncie wide or close johken Transmission - Rearend 9 03-14-2006 02:12 PM
A turbo 350 or a Muncie m-22? n2o burner Transmission - Rearend 11 02-15-2006 06:47 AM
Which Muncie Do I Choose? JimKramer Transmission - Rearend 9 09-09-2005 09:21 AM
Muncie shifter adjustments needed? Jims64 Transmission - Rearend 2 12-21-2004 11:01 PM
Swapping a Muncie SM465 to a TH-350 on a FS Chevy Truck TL-Iguana Transmission - Rearend 1 08-22-2004 05:54 AM
