Muncie hurst shifter will not go in reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2011, 08:50 PM
I can't get my Hurst shifter to shift my muncie into reverse. I have tried adjusting the linkage using the 1/4" drill bit method with no luck. I can shift the transmission into reverse if I get under the car and manually do it, but the shifter will not budge left and up. It will shift 1 through 4 with no problem. I disconnected the reverse linkage from the shifter (leaving the 1-4 linkage attached) and that wouldn't allow me to shift the lever into reverse either. I can't tell if the shifter isn't able to go left enough or if it is bound up when I try to push it up after I push it left. This shifter has been this way since I bought the car a few weeks ago. What should I look for?
Old 01-02-2011, 09:06 PM
ericnova72's Avatar
More for Less Racer
Is the linkage arm on the trans withthe correct orientation?? reverse lever should point down from the bolt that holds it to the trans.
Old 01-02-2011, 09:56 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I pulled a very hard shift in my '65 GTO once, it was brand new, and it rotated the shifter brcket to the rear just enough to cause shifting issues.
Old 01-03-2011, 06:17 AM
The linkage was in the bottom hole and I moved it to the top hole after reading another online post, but that didn't solve my problem. I'll take another look.
Old 01-03-2011, 06:18 AM
Are you referring to the shifter bracket that mounts directly to the transmission or a bracket within the guts of the shifter?
Old 01-03-2011, 06:37 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Worn bushings will play havoc on easily getting reverse.
You should be able to feel the rather strong spring pressure that pushes the lever back towards neutral. If you're not feeling that, the alignment isn't correct.
The alignment can be done w/a 1/4" bit and still (w/worn bushings) be problems w/getting reverse.
A similar problem and resolution- http://www.camaros.net/forums/archiv.../t-166212.html
Old 01-03-2011, 07:15 AM
I advise all my customers to buy a 'Hurst Pit Pack' (bushings and spring clips) and to usually opt for the HPP with the steel parts instead of the nylon.
Since most of my customers will be doing an R&R with the trans and removing the shifter, it only saves aggravation later.
Also, it seems since Hurst has changed hands 47 times or whatever, their stampings and castings have degraded substantially. One of my customers has a page on his site dedicated to this problem. Brand new shifters so out of whack that the linkage rods run into each other.
Heres a link to the page on his site:
http://5speeds.com/shifter.html
HTH and YMMV
Nate
Old 01-03-2011, 07:20 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Hey Nate (or anyone else)-
Who sells the OEM-type Hurst shift levers that 'snap' in place instead of bolt on?
Actually, all I really need is a broken lever- just the part that enters the shifter, plus a couple inches- so I can graft on the stick shape I need for a wagon bench seat.
Old 01-03-2011, 07:27 AM
Cobalt,
are you referring to the little shift levers that push into the sidecover, that are pre-1969 or thereabouts? These "stud mount" shifter shafts were a poor design. We make a replacement that is the same dimensionally, but uses the bolt on design.
No one makes the ones with the stud on them as far as I know; so you'll have to source a NOS set.
I hope this is what you were looking for LOL, If not, my apologies.
Old 01-03-2011, 08:40 AM
302 Z28's Avatar
Is your Hurst shifter new or used? Sounds as if it's used and you have some wear issues to deal with.
Vince
Old 01-03-2011, 08:51 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by AutoGear
Cobalt,
This doesn't have a stud, it attaches much like the headrests of about the same era, you remove it by inserting a taped over hacksaw blade between the shift lever and the spring-loaded pins that secure it.
PM sent.
Old 01-03-2011, 11:11 AM
Vince
The shifter appears to be used. The linkage from the shifter to the transmission and the nylon bushings appear to be new. Do these shifters have a common area where they wear out? I have never torn one apart.
Old 01-03-2011, 11:16 AM
HTH and YMMV
Nate
I'm not sure which rods they were without looking again, but I noticed that two of the rods are touching depending on which gear I was in. I believe they were the 1-4 rods, but it could have very well been the reverse rod. I thought to me self, "that's odd they are bent that way." Thanks for the link, I will check it out later when I get home.
Old 01-03-2011, 11:28 AM
Thanks, I'll start by inspecting all of the bushings and I'll try the 1/4" pin alignment again. That seemed to solve the problem in that forum.
Old 01-03-2011, 12:06 PM
302 Z28's Avatar
As mentioned when the 1/4" pin or drill bit is inserted you should be able to move the shifter all the way over to your left and feel the spring tension for the reverse lever.
Vince
Need help with Hurst shifter I.D. junior stocker Transmission - Rearend 5 05-08-2009 11:15 PM
hurst shifter 4b316 Transmission - Rearend 1 08-31-2008 11:11 AM
ST-10 Hurst Shifter jamming Brimstone Transmission - Rearend 1 08-11-2008 03:47 PM
hurst/muncie shifting problem the dan Transmission - Rearend 7 07-18-2008 02:04 PM
Hurst Shifter Linkage Schoust Transmission - Rearend 5 02-02-2004 11:04 PM
