muncie m20 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2008, 04:01 PM
vette ftw
muncie m20
i've got 74 vette with a new longblock on the 350 and a muncie m20 transmission and the thing aint real good at off the line accel so i was thinking of puttin 3.73 or maybe 4.10 gears in the rearend to help. Would i have to buy a whole new rearend and would this help my accel problem?
Old 05-05-2008, 07:14 PM
BORTI's Avatar
BLOWN 357
3.73 Or 4.10
In your vette I think 3.73 should be plenty of gear.But I would first check your distributor advance curve and carb,you probably only need some adjustment.The four speed would make up any short falls your motor might have.
Old 05-07-2008, 02:41 AM
I don't know what gears you have now, but I can vouch for the fact that an M-20 with 3.08's is a PITA to get moving without slipping the stink out of the clutch, especially considering the soggy bottom end typical of the early-'70s smog motors.
I changed my '72 Nova from a Saginaw with a low gear similar to an M-20 to a Sag with a 3.11 low gear, a change that would mimic a change from 3.08 to 3.73 gears, and I like it MUCH better.
Old 05-08-2008, 01:14 AM
i was considering using a saginaw with the 3.11 1st gear. how are you guys getting them to hold up at the drag strip?
Old 05-08-2008, 02:26 AM
Probably should have started a new thread for that question. Maybe a moderator could make it into a separate thread, and Grusome Goat might chime in. He's been beating on them for quite a while.
I don't race mine, but a stock clutch and tires no wider than 235mm have helped mine tolerate some fairly harsh street driving.
Old 05-08-2008, 02:40 AM
took your advice started a new thread thanks, i was always told in a 4 speed drag car unless you can afford a dual disc-er to do one of 2 things. one, run a bad *** pressure plate with a stock disc or a bad *** disc with a stock pressure plate its suppose to allow enough slippage without grenading anything to badly. must work couple of guys here leave at 7200 on the slicks and have had good seasons. i currently have mickey sportsmans they dont hook very good anyway at least with a stick u can somewhat control your spin at the launch.
muncie predicament the dan Transmission - Rearend 5 08-06-2007 10:33 AM
Muncie problems Muncie guru needed chirpn69 Transmission - Rearend 8 04-19-2007 10:28 AM
Muncie hub width mr52pickup Transmission - Rearend 3 02-12-2007 06:39 AM
trying to decode my muncie M20 TCAMARO Transmission - Rearend 1 05-12-2005 04:55 PM
Muncie M20 Input shaft deflection RogP Transmission - Rearend 6 08-21-2004 09:42 PM
