Muncie M20 Input shaft deflection - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2004, 05:11 PM
My input shaft deflects about 1/8 inch at the tip.
Is this acceptable? Bearing is fairly new and appears
to be ok.
Thanks.
Old 08-21-2004, 05:58 PM
302 Z28's Avatar
Perfectly normal, be sure the pilot bearing in the flywheel is OK.
Vince
Old 08-21-2004, 06:57 PM
Yep, the pilot bearing is worn and lodged in the flywheel* pretty well. Any tips how to get it out?
*actually it's in the end of the crank, not the flywheel of course.
But that fricken thing is lodged in there pretty tightly.
Old 08-21-2004, 09:43 PM
BOBCRMAN@aol.com's Avatar
Pack the hole full of wheel bearing grease. then find a dowel (steel or wood) that just fits the ID of the hole. Hammer the dowel into the hole. Hydraulic pressure will force the old pilot bearing out. Works every time.
Old 08-21-2004, 09:51 PM
302 Z28's Avatar
Bob is right on, just use a thick heavy bodied grease. It has worked every time for me.
Vince
Old 08-21-2004, 09:56 PM
Last journal entry: PICTURE TEST
input
There are many different input bearings made for that transmission. Some of them have a few as 8 rollers in them and others have 12 or 15. Plus then there are different precission grades. If you have a bearing with a low number of rollers in it then it a normal amount of play. If its a more precission bearing with a higher roller count then the bearing might be shot......
Keith
Old 08-21-2004, 10:42 PM
Thanks for the dowell tip. I would never have thought of that.
Will try it tomorrow morning.
Don't recall how many exactly how many ball bearings were in the bearing, but it had to be more than 8.
