Muncie M20 Won't go into first gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2009, 03:41 PM
I have a Muncie M20 that I serviced with new bearings and syncros. I have never used this transmission before the service. It won't go into first gear, I adjust the linkage and first will work but second gear won't. I adjust again and I'm back to the original problem with no first. Could this be the shifting forks worn out? Thanks
Old 05-01-2009, 04:52 PM
302 Z28's Avatar
Could be a number of problems
Shift forks worn out
Synchro drums worn out
Side plate installed incorrectly
Engagement teeth on gears worn
Vince
Old 05-02-2009, 12:58 AM
ericnova72's Avatar
More for Less Racer
If you have a Hurst shifter, this could be as simple as a badly misadjusted shifter stop on the shifter main body. Have a look.
Old 05-03-2009, 06:29 PM
Last journal entry: PICTURE TEST
trans
My vote is the shifter stops.
Keith
Need Help with 700r4 No 4th Gear Jackson63 Transmission - Rearend 7 04-20-2015 10:45 PM
Muncie Trannie Shifter just flopping around. Marky-Marc Transmission - Rearend 14 03-31-2009 08:33 AM
Muncie, Drops out of 3rd. gear Ted's37 Transmission - Rearend 13 02-16-2007 07:13 AM
What Gear Lube For My Rebuild Muncie JimKramer Transmission - Rearend 2 03-22-2006 09:38 AM
Muncie M20 Input shaft deflection RogP Transmission - Rearend 6 08-21-2004 10:42 PM
