Muncie M21 leaks
Thanks,machine shops are having a rough go of it,some in this area are closing,a good deal on a mill may come along. Thanks again for your input! Dana
Muncie M21 leaks
Hey Ian,thanks for the words of caution,sounds like you may have had a bad experince,in this area mate. Will heed your warning,what k-star is doing is a neat idea anyway. And by the way,glad to see you were smart enough to wear ear plugs.
muncie
Ian, I too have considered the approach of shorting the counter shaft and installing a flat plug in the case.. But i keep thinking that when you do it you will be removing more area of the shaft to case contact.... I know 1/8" is not alot but since it's a problem now making it less would only add to the issues..IMO...
I feel i would rather have a small leak then take strength away from the pin support.... Keith |
How about 4 tapped holes with a flat plate cover, it would need a small dia drain back hole into the case - say 45 degrees at 6 o'clock.
Further, like crankshafts in some early engines you could cut a 5 thou coarse thread- an 'Archimede's screw' in the cluster shaft. Ok the shaft doesn't turn but the rollers should drive the oil rearward into the case. Ol' Arc was a switched on cat for an ancient Greek, his screw still lifts millions of tons of grain and water every year. Dunno if you folks get world news but the bushfires are pretty bad here, lots of smoke - visibility down to a 1/4 mile at times. |
| muncie m21 vs m22 | chrisf67 | Transmission - Rearend | 3 | 06-04-2006 06:57 AM |
| muncie m21 question | rh4414 | Transmission - Rearend | 3 | 12-19-2005 10:23 AM |
| Which Muncie Do I Choose? | JimKramer | Transmission - Rearend | 9 | 09-09-2005 09:21 AM |
| Cross leaks in the 4L80 pump. | Jason | Transmission - Rearend | 2 | 09-28-2003 06:46 PM |
| Muncie M21 Question | Camarox302 | Transmission - Rearend | 6 | 06-04-2003 08:52 AM |
