Muncie M22 Rock Crusher 4 speed - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2003, 01:26 PM
New Member
Post Muncie M22 Rock Crusher 4 speed
Can someone tell me how much a muncie m22 rock crusher is worth this transmission was produced buy gm in 1966&1967
Old 02-22-2003, 01:39 PM
Post
I do not claim to be a transmission expert and could be wrong but the "real" rock crushers had straight cut gears....not helical cut gears. I believe they were first released by GM in 1969 or 1970.
I had one in my 1970 Chevelle SS 454-450HP LS6 car. I bought it new. The Rock Crusher was very noisy due to the straight cut gears.
Maybe someone in the past (it has been 30 years) put all the goodies in a early case maybe?
<img src="confused.gif" border="0">
Old 02-22-2003, 01:57 PM
New Member
Post
The m22 was available as early as 1965 in Corvetts
Old 08-18-2003, 01:29 PM
I had a 71 GTO with a M22 "rock crusher". This was an absolutely stout transmission. Had a distinctive "whine" due to the slanted gears.
Old 08-18-2003, 04:26 PM
302 Z28's Avatar
M22 had straight cut gears, all other Muncies had helical cut gears. The straight cut gears gave the M22 it's different sound. Other Muncies were quite compared to the M22.
Vince
Old 08-19-2003, 12:16 PM
Sandflea427SS's Avatar
Anything with a throttle
Many people have guesses about deciphering M-22s. Like grooves in the input shaft and numbers and etc etc...
The only way to tell is to open the case and measure the gear angle from the shaft centerline. M-20 and M-21 have 45 degree gears and M-22 have 22.5 degree gears.
Fresh M-22s are going for $1300-$1600
Old 08-20-2003, 05:09 PM
302 Z28's Avatar
Everything you wanted to know about Muncies.
http://www.gearzone.net/muncie.htm
Vince
