Muncie parts - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-19-2005, 03:26 AM
clutchless
Accelerated wear will occur if you don't master the art. Practise with 2 fingers on the shift lever, if it goes in smooth you're on the money, if not try again, but be gentle. When you've got it sussed wear will be less than using the clutch. Ask anyone who rebuilds road rangers, I've seen them worn across the gear teeth at low miles by bad drivers and fine at over 400,000 miles when used by a DRIVER.
First practise knocking it out of gear rolling to a red light, it wont come out under load, but it will on overrun, go from there.
  #17 (permalink)
Old 10-19-2005, 03:11 PM
I dun learned sumthin
Got some practice just the other day when the double nut on the clutch rod came loose and the clutch wouldn't disengauge. That was sure a fun time (sarcasm). But I can see were it is a good skill to master.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Parts Indentification Manuals question JhnBrackett Hotrodding Basics 1 12-01-2004 11:02 AM
Parts runner CV joint johnsongrass1 Transmission - Rearend 5 05-18-2004 07:34 AM
1964 Muncie M-20 parts question 1964 Oldsmobile 442 Transmission - Rearend 3 04-10-2004 09:25 PM
parts? i dont need these stinkin parts! bullheimer Hotrodders' Lounge 7 02-12-2004 10:42 AM
