Muncie question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2006, 11:31 PM
Muncie question
Can muncie m21's be upgraded to the m-22? If so, how can you tell if you have a m-21 that was rebuilt as an m22? What needs to be looked for.
Old 10-22-2006, 08:20 PM
>Can muncie m21's be upgraded to the m-22? If so, how can >you tell if you have a m-21 that was rebuilt as an m22? What >needs to be looked for.
Yes, provided it's the version with the 1" countershaft pin instead of the earlier 7/8" pin. The M21 and M22 have the same ratios, but the M22 get's it's additional strength from having a less helical angle on the gear teeth. That's also where it gets it's additional noise. Unless your very familiar with Muncies, it can be difficult to determine if it's an M21 or M22 by looking at the gears unless you see both side by side, then the difference is apparent.
Bob
Old 10-22-2006, 08:33 PM
the gears look like this, can anyone tell from this pic?
Old 10-22-2006, 08:52 PM
Check this link for more info and pictures.
http://www.5speeds.com/muncie3.htm
Bob
Old 10-23-2006, 01:01 PM
Last journal entry: PICTURE TEST
trans
If thats the picture of the transmission it's a m20/m21 not a m22....
Keith
Old 10-23-2006, 06:39 PM
kain13's Avatar
^^^^what he said!!!!
supercharger.... 73monte Engine 16 07-24-2010 11:27 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 08:35 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 02:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 11:25 AM
Muncie tranny question cabrio Transmission - Rearend 3 10-02-2003 01:17 PM
