Muncie question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2010, 02:11 PM
Muncie question
Hoping someone can give me some guidance here: I have an M21 and two of the shifter shaft seals are leaking, which I understand is par for the course for Muncies. I saw a reference somewhere online that with a special tool the seals can be removed and replaced from the shafts without taking off the side cover. Is this true? If I remove the bolts that hold the shifter linkage to pull the old seals and put in new ones, aren't I dropping the shaft inside the case? Thanks for any advice you can offer.
sr
Old 12-08-2010, 02:28 PM
ericnova72's Avatar
More for Less Racer
The shafts can't fall into the case because the other end of the shaft is the connected to the shift forks, which are around the syncronizer slider rings. Everything is held in place, there is no way the shafts can fall into the case.
One way to remove seals like this is to drill two small holes 180 across from each other in the steel portion of the seal and thread in a couple small sheetmetal or wood screws to give you something to pull on.
Old 12-08-2010, 03:10 PM
Muncie question
Thanks very much! I'll try it. sr
Old 12-08-2010, 03:54 PM
302 Z28's Avatar
Remove them as stated then install them with a properly sized deep socket and dead blow hammer.
Vince
Old 12-10-2010, 09:46 AM
I dont have the national number handy but the chicago rawhide is 7410cr
Old 12-10-2010, 01:32 PM
Quick and easy seal puller
Slip a steak kinfe between the shaft and seal and pry the seal out.
This method workes much easier than drilling a hole and using a screw.
Bob
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
Muncie question gilliganspl Transmission - Rearend 5 10-23-2006 05:39 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
Muncie tranny question cabrio Transmission - Rearend 3 10-02-2003 12:17 PM
