muncie question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2005, 06:37 PM
muncie question
ok guys , i did a search and couldn't come up with much. i'm putting a 64-65 m20 into my chevelle and this is the first manual trans i've ever worked with. my questions are , how much gear lube does this thing take , along with what weight? and where is the best place to fill it through? sorry if these are stupid questions but i'm a complete rookie when it comes to manual trannies.thanks.
Old 06-24-2005, 08:07 PM
302 Z28's Avatar
With the trans sitting level, fill it through the plug in the side until it just starts to come out the plug hole. Gear lube in the 75w to 80w range will suffice. If it were mine I would run Royal Purple Max gear lube in it.
Vince
Old 06-25-2005, 04:00 PM
thanks vince ,
ok , the plug that i have is about 3" up from the bottom , on the passenger side , i'm assuming this is the one i want? i hope so because it's the only one i have. so if this is correct , then only the bottom third of the tranny has lube in it? do you think 2 quarts would cover it?
Old 06-25-2005, 09:21 PM
I'd get a gallon and change the rear end oil also. After you run that tranny some, check the level again.
Old 06-26-2005, 07:06 AM
i just put a rear end in it about a month ago , but other wise that would be a good idea.
Muncie Tranny Question Brads67 Transmission - Rearend 39 05-27-2009 01:33 PM
Muncie tranny question cabrio Transmission - Rearend 3 10-02-2003 12:17 PM
Muncie M21 Question Camarox302 Transmission - Rearend 6 06-04-2003 08:52 AM
Muncie Trans question FamilyMan Transmission - Rearend 3 04-02-2003 07:49 PM
Muncie or Saganaw that is the question. Rodrunner Transmission - Rearend 22 03-19-2003 03:07 AM
