Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - muncie stuck in reverse
Old 12-24-2011, 09:43 PM
tjet tjet is offline
When I did the clutch on my '71 Vette, I had to disconnect & remove the shifter, but it's a Hurst.
Put it in netural, & disconnect the linkage at the trans. If the linkage on the trans moves or spings to the detent when the linkage rod is disconnected, the linkage will need to be adjusted.
Did you replace the input shaft pilot bearing too? Some are too small
