muncie stuck in reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2011, 07:09 PM
replaced the clutch and flywheel on my 73 vette before i put my new motor in. now problem is the car is stuck in reverse. when the motor is on i have to keep the clutch in or the car will move back. shifter moves though the other gears when motor is on.its even in reverse when i put it in other gears. when the motor is off i can shift through the gears but wont go into reverse. any help please
Old 12-24-2011, 07:13 PM
Did you try disconnecting the linkage to see if it's adjusted properly?
Old 12-24-2011, 09:37 PM
Didn't think I had too never disconnected anything on the tranny
Old 12-24-2011, 09:43 PM
When I did the clutch on my '71 Vette, I had to disconnect & remove the shifter, but it's a Hurst.
Put it in netural, & disconnect the linkage at the trans. If the linkage on the trans moves or spings to the detent when the linkage rod is disconnected, the linkage will need to be adjusted.
Did you replace the input shaft pilot bearing too? Some are too small
Old 12-24-2011, 09:54 PM
Yeah I replaced the pilot and throw out bearing. Should I disconnect the reverse first befor the other gears. Didn't think I had too being I didn't remove the tranny or linkage.
Old 12-24-2011, 10:03 PM
If the shifter is in netural, the linkage arms should be in netural. It's easy to see once you pop the rod off.
The prob I had was that pilot brg ID was tight on the input shaft.
How is the clutch adjustment? How much free play?
Old 12-26-2011, 06:50 PM
Messed with the tranny today and notice that the shift nob had came a little loose tighten it down and bingo !!!! Problem solve thanks fellas
Muncie hurst shifter will not go in reverse hoffmandirt Transmission - Rearend 18 01-04-2011 06:41 AM
Muncie stuck in reverse? Mets63 Transmission - Rearend 4 06-22-2009 07:20 PM
700R4 stuck in reverse famous 4130 Transmission - Rearend 5 11-28-2008 10:17 AM
55 stuck in reverse-any ideas Slickriffs Transmission - Rearend 3 05-27-2007 03:16 PM
Muncie 4 speed stuck in Second greasysideup Transmission - Rearend 3 02-05-2005 03:36 PM
