Muncie Tailshaft Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2005, 03:44 PM
I dun learned sumthin
Hey I was in the process of removing the retainer pin that hold in the reverse shift lever and managed to crack the tail housing. The crack is in the part where the reverse shift lever goes into the case. This shouldn't be a stressed part of the case but my question is should I try and find someone to weld this or can I use JB weld on it and silicon it to prevent leaks. Its cast aluminum so I would have to find some one to weld it.
Old 11-23-2005, 04:03 PM
New Member
Hey
Please don't use jb or sicicone or other gueeeeeee.
Bring it to a machine shop and have them weld it them check bore where the shaft comes so that a new seal will properly fit. Lou
Old 11-23-2005, 05:18 PM
302 Z28's Avatar
I have several old rear cases, PM me with the casting nuber off it and I will see if I have one the one you need. Price will be right.
Vince
Muncie Tranny Question Brads67 Transmission - Rearend 39 05-27-2009 01:33 PM
Muncie tranny question cabrio Transmission - Rearend 3 10-02-2003 12:17 PM
Muncie M21 Question Camarox302 Transmission - Rearend 6 06-04-2003 08:52 AM
Muncie Trans question FamilyMan Transmission - Rearend 3 04-02-2003 07:49 PM
Muncie or Saganaw that is the question. Rodrunner Transmission - Rearend 22 03-19-2003 03:07 AM
