Muncie tranny question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2003, 02:15 PM
I have a Muncie in my '67 GMC truck that grinds a little going into 4th gear and back-shifting into 3rd. It only happens after the gear oil is warmed up. I put SAE 85-140 Turco in it, but that didn't stop it. It has plenty of clutch throw.
Are there springs under the synchros that stop the front shaft freewheeling? I'm not a tranny heavy.
Can anybody shed some light on this?
Old 10-01-2003, 08:01 PM
BOBCRMAN@aol.com's Avatar
The condition you describe is due to worn out synchros or a bearing about ready to depart, the assembly is moving and the synchro teeth and dogs can't slow the gear down, grind,,,, as it gets worse it will start popping out of gear.
Old 10-02-2003, 04:53 AM
302 Z28's Avatar
Time for new synchros.
Vince
Old 10-02-2003, 12:17 PM
Muncie tranny ?
Thanks, guys, for the info!
