-   -   Muncie Transmission 451 or 452 (http://www.hotrodders.com/forum/muncie-transmission-451-452-a-197177.html)
Fathertime35 04-25-2011 04:12 AM
How do you tell a muncie 4 sp no 451 or 452 can not see any nos,plus i believe shift linkage is wrong this is on 64 GTO. There is hurst shifter but original linkage if we put levers on side of trans up like they are suppose to be can't shift as linkage hits tunnel
302 Z28 04-25-2011 07:50 AM
Try this link and next time use a little punctuation. :D
cobalt327 04-25-2011 08:16 AM
#451 ('63-'68)- shift arms attach w/stud and nuts.
#452 ('69-up) shift arms attach w/bolts.
No grooves or number of grooves if present on input shaft can indicate ratios.
There were several different 4 speed Hurst shifters used depending on application.
oldschool hero 04-25-2011 08:21 AM
The transmissions all have the same dimentions, it's the shifters that are different. Some think that just because it's a Hurst shifter it will work on any car.WRONG.
AutoGear 04-26-2011 10:12 AM
Don't forget your speedometer drive should be on the drivers side of the tailshaft housing for a Pontiac of this vintage
