Muncie Transmission 451 or 452 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2011, 04:12 AM
How do you tell a muncie 4 sp no 451 or 452 can not see any nos,plus i believe shift linkage is wrong this is on 64 GTO. There is hurst shifter but original linkage if we put levers on side of trans up like they are suppose to be can't shift as linkage hits tunnel
Old 04-25-2011, 07:50 AM
302 Z28's Avatar
Try this link and next time use a little punctuation.
Old 04-25-2011, 08:16 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
#451 ('63-'68)- shift arms attach w/stud and nuts.
#452 ('69-up) shift arms attach w/bolts.
No grooves or number of grooves if present on input shaft can indicate ratios.
There were several different 4 speed Hurst shifters used depending on application.
Old 04-25-2011, 08:21 AM
The transmissions all have the same dimentions, it's the shifters that are different. Some think that just because it's a Hurst shifter it will work on any car.WRONG.
Old 04-26-2011, 10:12 AM
Don't forget your speedometer drive should be on the drivers side of the tailshaft housing for a Pontiac of this vintage
Muncie 4 speed transmission hotchevellechick72 Transmission - Rearend 2 02-27-2010 09:25 PM
Muncie Transmission Questions mikeand67 Transmission - Rearend 4 03-02-2008 08:10 PM
Muncie 4 Speed Transmission junkyjerry Transmission - Rearend 2 10-29-2006 07:40 AM
What transmission Muncie or TH400? CamaroRage Transmission - Rearend 4 09-17-2006 09:12 AM
Muncie 4 speed transmission dzguy Introduce Yourself 3 10-01-2004 01:59 PM
