I would have to look at the pictures again but I believe it was just a t-bucket frame with early ford axle and just had the coffin body instead of a t-bucket..
He hasn't been here for a few years. Maybe drop him a p.m., he may have email notification. You can click on the profile link and see when a member was last active. Dan
I have been playing with the thought of building one, but I have the idea of using 2 caskets and putting them together side by side so that a driver and passenger ride together and so it would have a big enough fuel cell you would not have to stop every 5-7 miles for gas. I have been looking at Speedway for the steering parts. Have the 2 lids open from the side hinged in the middle or weld together in the middle and open like the corvettes with the hinges up front for the engine compartment. I get a idea and I kind of sketch it out and write it down. There is a article about the building of the original car on the net but not much detail about the build except how they fabed the coffin up from fiberglass. I have been collecting a little here and there for it. I should be able to start on it after I get my grandsons Camaro finished this year.
There is a article about the building of the original car on the net but not much detail about the build except how they fabed the coffin up from fiberglass. .
huummmm. I'd always heard the original car had a real coffin, and that it was very hard for them to purchase one when the funeral homes found out what they wanted to use it for. they had to go to several funeral homes before finding one that would sell them a coffin.
I'm old, so maybe my memory is going also....?????
You can get special extra wide caskets too, I used to deliver to mortuaries and saw some unusual caskets the wide one I saw was for a obese 780 pound guy they were putting him in it with a cherry picker,the fanciest was for a Cubs fan it had baseball bats for handles and all done in Cubs colors and logos.
The first casket was fiberglass from the prop room that they cut it in half and lengthend it from what I understand. found pictures but cat find the article. The next 3 were coffins that were purchased in Mexico. Heres the article with one of the builders. http://www.munsterkoach.com/dean1.htm
i belong to that site. im putting the engine on the out side of the casket just have the transmission on the inside use the front on the box sorta like the firewall. plenty of room as far as i can tell for battery,and etc. also keep the engine kooler. if u go on that site u notice the front of the movie car the lid was proped open, also the tv car had to be rebuilt front end was damaged notice spring shackles were welded and the frame was made of square tube instead of the round .
Since this thread was started 5 years ago. We have opened a T Bucket shop and we make a cowl steering kit. We have sold several to guys building coffin cars already. Here are a few pics of how it is done. A flanged hub is made, with splines to fit the steering box, leaving enough room to install a lock washer and nut. Then the extension is machined and cut to length. Then the hole is made in the body. The shaft is cut to length and then the pitman arm is welded on. Contact phone # 865-932-7541
t
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
