Obviously you are determined to do this but just as with body work if you do you will in all likelyhood regret it. The problem is that although it will remove the rust you see (actually what you see is NOT rust, it is the already oxidized byproduct of the rusting process which you can not see) it will set in motion a process that will lead to more damage than you have now. Once the acid contaminates the iron (ESPECIALLY iron castings which tend to be somewhat porous) the chemical reaction that starts will be nearly impossible to stop. Some will say you simply need to neutralize the acid, much easier said than done, and while steps to do this will slow the damage it hardly ever stops it completely. The rust solutions both dissolve the oxide on the surface and convert it to a phosphate that tends to stop the rusting process, the Hydrochloric (Muriatic) acid on the other hand will dissolve the oxides but as far as stopping the rusting process it will be like throwing gasoline on a fire! I have battled this for years on mining equipment that was exposed to Sulfuric acid and I can tell you that once the metal is contaminated it can really make a mess. It is not as simple as removing the iron oxides that you can see you must take into account the chemical process that you are about to start, and this is one that you don't want any part of! Do yourself a favor and use Phosphoric acid because it will remove the oxides also but it will start the right chemical reaction that will leave the phosphate coating that will inhibit rust instead of accelerating it. The Phosphoric acid may take a little longer but it is definitely the better way to go, usually the fastest way out of something just leads right back in!
oldred ...From what I read phosphoric acid IS the way to go "IF" you can submerge the part. I can't do that! But if your telling me all I need to do is wet the surface of the part with phosphoric acid, like muriatic acid, then I'll be happy to try. But as I indicated what the controlling factor are, WHAT would you suggest!??? ...I"m here to learn!
You are right in that submerging the part would be best but actually you really just need to keep it moist, cover the part with plastic maybe? I don't know if there are any economical sources for large quantities of a gel like Navel jelly but that would work if you can find something. Can these parts be sandblasted?
Yes these parts could be sand blasted (I'd have to tape up the machined surfaces). But now your getting into cost and mobility is an issue.
...SO how long would these surfaces need to be wetted with phosphoric acid solution? |
your procedure with muriatic acid right on, i use it full strength on small parts and to disolve rust inside antique motorcycle gas tanks i restore. you have to neutralize it with baking soda. but i'm with oldred, muriatic acid is nasty stuff, if not COMPLETELY neutralized, the rust will come back almost right away. try phosphoric acid or electrolisis, muriatic acid on big parts is impracticle. oldred knows his stuff.
Muric acid rust control
I wipped down my bare steel 37 chevy body with picklex 2 years ago and it hasn't rusted yet.they use it in the powder coating industry.the company is out of arkansas and sent me a quart for free. it makes the metal easier to mig weld and can be painted over without removal because it is an etching chemical.
I have used Rust Mort with a good success on things of that nature..Just follow instructions when using it..Then get some primer on as soon as practicable..I like the epoxy's as they hold up a lot better and seal against further rust..
Just my 2 cents Sam
Don't use muriatic on cast iron...period. If you soak a cast iron part for a while, it will look like the moon...only the craters will be deeper
That is what I meant earlier when I said "especially cast iron" because it is slightly porous and will retain some of the acid. I guess technically it may not actually be porous but the irregular micro-grainy type surface will be just as bad. |
Found some information that might be relevant here:
MSDS for Picklex [PDF] Less than 10% phosphoric acid MSDS for Rust Mort (Leads to a PDF) phosphoric acid 25 - 50% I'm kinda partial to 19th century writing, so I dug up an old book: A Dictionary of Chemistry, On the Basis of Mr. Nicholson's; The Principles of the Science are Investigated Anew, and Its Applications to the Phenomena of Nature, Medicine, Mineralogy, Agricultures, and Manufactures, Detailed. By Andrew Ure, M.D., 1821 "Diluted muriatic acid rapidly dissolves iron at the same time that a large quantity of hydrogen is disengaged, and the mixture becomes hot." "Phosphoric acid unites with iron, but very slowly." I don't think basic inorganic chemistry has changed all that much since 1821, so you have a choice of acid that dissolves or acid that unites. BTW, keep in mind that one of the things produced from putting muriatic acid on iron is ferrous chloride -- used for etching -- so it's an accelerating process. Leave it on too long (how long is that?) and you could end up with holes or hydrogen embrittlement. Leave phosphoric acid on too long and you get iron phosphate -- a rust inhibitor. |
I think when someone is contemplating using Hydrochloric/Muriatic or even battery acid for rust removal, and this has come up a bunch of times here, they tend to look at acids in the wrong way. There seems to be a misconception that "acid" is a substance in itself instead of being just one of the properties of different chemicals that happen to be acidic, thus the mistaken idea that acid is acid just some acids are stronger than others. Phosphoric acid and Muriatic acid are two different chemicals that affect iron in drastically different ways but because Phosphoric acid removes rust then some get the idea that a stronger acid would work even better. Also that book makes a good point in that the way different acids affect iron has been well known for a heck of a long time and if Muriatic acid or Sulfuric acid (sulfuric acid for rust removal has come up a couple of times) were a good choice for rust removal they would be popular for that use, they are not.
Just come on down here to sunny South Florida and look at all of the rotted out pool trucks.
This subject has been beaten to death, and I still can not comprehend how anyone would even begin to consider using muriatic acid on any type of metal. |
So wirebrush it off,+ Slap a coat or 2 of Rustolium on it........ No Muss, No Fuss,.... If it chips, touch it up...... You'll be a Pile of Dust, long before those Cast Iron Parts are..... Quote:
It "Antiques" them,....... Really Quickly............
| Recent General Rodding Tech posts with photos |
| Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
| secrets of surface rust removal revealed | Randy Ferguson | Body - Exterior | 178 | 09-24-2011 09:36 AM |
| phosphoric acid based rust dissolver | rlackey | Body - Exterior | 15 | 01-05-2006 07:07 PM |
| Rust Dissolver versus Rust Convertor? | 66GMC | Body - Exterior | 9 | 11-06-2005 05:48 PM |
| The secrets of rust removal part II | Z51JEFF | Body - Exterior | 3 | 11-04-2005 08:34 AM |
| Phosphoric Acid + Prevention of flash/surface rust | unstable | Body - Exterior | 3 | 07-21-2003 07:36 PM |
