Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Muriatic Acid Rust Removal
Old 02-22-2008, 05:34 PM
bondo's Avatar
bondo bondo is offline
BUT it has allowed a surface rust to form on all the parts. SO I need to remove this rust and re-paint. This mill is broken down to about 6 LARGE parts i.e. they are large, and being cast iron weight a ton!
Ayuh,....
So wirebrush it off,+ Slap a coat or 2 of Rustolium on it........
No Muss, No Fuss,.... If it chips, touch it up......
You'll be a Pile of Dust, long before those Cast Iron Parts are.....
I still can not comprehend how anyone would even begin to consider using muriatic acid on any type of metal.
Ayuh,.... I use it on steel sculptures,......
It "Antiques" them,....... Really Quickly............
