Mus II dimentions - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2005, 07:03 PM
Gr8 '48 bow tie's Avatar
Be American, Buy American!
Mus II dimentions
Are all Mustang II dimensions the same? Reason? I want to go to salvage yard to look for one and do not want to buy something i can not use. Next question. I understand that there are some aftermarket bolt in kits which leads me to this question. Are the original mustang II IFS bolt in or weld in.
Al
Old 06-03-2005, 09:45 PM
The Pinto/MustangII suspension that everyone seems to prefer is the 74 -78 Models. The original cross members and locating points were welded in.
They came stock with 4 lug wheels and 9 inch brakes.
IMHO...they are NOT for a lot of the heavier vehicles you see them under Light cars like the Pinto and MustangII ............yes
A lot of folks DO NOT match their stuff up right IMHO. If you have a 3500 lbs vehicle .....you do not need a 2000 lbs vehicle suspension NOR do you need a 5 ton front end from a F-350.
Old 06-03-2005, 11:06 PM
Thanks Deuce, I was thinking along those lines too but was not 100% sure since nearly everyone uses the Mu II. Are the aftermarket kits built up to withstand the weight of larger cars. On the title, my cars weight is 3300 lbs. Perhaps I should look for Camarro or Nova.
Al
Old 06-03-2005, 11:15 PM
willys36@aol.com's Avatar
Wiki Edits: 21
This is probably the most discussed topic on the board. Do a search for a bunch more info. Have you followed this thread? The Pinto/MII suspension is actually pretty good for bigger cars than you might think. Whereas most cars (rods especially) have the front axle far in front of the engine center of gravity, the host cars were designed with the front X-member way under the engine so it carries a bunch more weight than you might think. In fact, the strongest MII springs are too strong for virtually all rods with the classic axle configuration. 4 cylinder springs are usually the best match for even big V8s. Horvath (board member) has one under his '54 Chevy pickup and reports to be very happy with it.
Old 06-04-2005, 05:06 AM
Al
In your original request, the vehicle you were going to put a Pinto/Mustang II under was not mentioned. A lot of folks have the Pinto/Mustang II front under pickups like yours. At 3300 lbs, you should be OK. IF you load it like a truck....( over load it like most trucks ) ....? ?
As a side note, a lot of folks have a clip under that year truck also.....
....because that way they do not have to up grade the brakes and the suspension is more heavy duty ( came from a heavier vehicle .....from the factory ).
IF you go with a bolt in kit for a Pinto/Mustang II, I would weld it in.......after I got it installed and do not, whatever you do........run it without the lower A arm brace........( strut arm support ...I believe is the correct name) Stock Pinto/Mustang II's have it and so should you. This is where MOST of the bad rap Pinto/Mustang II front comes from.
DEUCE........
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
Must II p.s. Don Meyer Suspension - Brakes - Steering 4 06-16-2004 11:28 AM
Best Ford caliper for 11" rotors on Mus II IFS Darkman270 Suspension - Brakes - Steering 12 03-06-2004 04:20 PM
Mus II Disc brake kit question Darkman270 Suspension - Brakes - Steering 1 02-18-2004 07:46 AM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 12:43 PM
