Mus II Disc brake kit question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2004, 08:37 PM
Darkman270's Avatar
The GM rotor is taller so it requires a spacer to fit the Mus Ii spindle. Where does this spacer go? After using the spacer if you had a rotor that was about a 1/4" taller than the GM rotor did you have enough room on the spindle for a extra 1/4" spacer?
Old 02-18-2004, 08:46 AM
Wiki Edits: 49
If you're using a kit the rotor should fit the spindle fine after the installation of the new bearings. Also if you're using GM rotors then you should use GM calipers and the mounting brackets which should have come in the kit.
Centerline
